Heat Barriers
poasttown(at)yahoo.com
PostPosted: Sat Jun 07, 2014 3:51 am    Post subject: Heat Barriers Reply with quote
I'm getting ready to repaint my cowling and would like to add some sort of heat barrier to the inside cowling to help shield the cowling from the engine heat. What type of heat barriers have members of this list found to be effective?
Mike Chaney
1996 Kitfox IV
Jabiru 2200
n223rv(at)wolflakeairport
PostPosted: Sat Jun 07, 2014 7:59 am    Post subject: Heat Barriers Reply with quote
Vans sells some sticky foil type of heat shielding I have used on several RV's with good success.
http://www.vansaircraft.com/cgi-bin/store.cgi?ident=1402156429-202-483&browse=engines&product=cowl_protector
On Jun 7, 2014, at 7:48 AM, Mike Chaney <poasttown(at)yahoo.com (poasttown(at)yahoo.com)> wrote:
[quote]I'm getting ready to repaint my cowling and would like to add some sort of heat barrier to the inside cowling to help shield the cowling from the engine heat. What type of heat barriers have members of this list found to be effective?
Mike Chaney
1996 Kitfox IV
Jabiru 2200
x-List"">http://www.matronics.com/Navigator?Kitfox-List
//forums.matronics.com
Guy Buchanan
PostPosted: Sat Jun 07, 2014 8:58 pm    Post subject: Heat Barriers Reply with quote
I used this stuff extensively. My 582 exhaust elbow used to come within 1" of it on the inside of my cowl with no deleterious effects. The only down side is that eventually the adhesive fails and you have to replace it. I'd say I replaced it every 2-3 years.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Sun Jun 08, 2014 2:50 am    Post subject: Heat Barriers Reply with quote
Or install it with a thin layer of high temp RTV and a plastic squeege like used for smoothing bondo or installing vinyl graphics....
On Jun 8, 2014, at 12:56 AM, Guy Buchanan <gebuchanan(at)cox.net (gebuchanan(at)cox.net)> wrote:
[quote] I used this stuff extensively. My 582 exhaust elbow used to come within 1" of it on the inside of my cowl with no deleterious effects. The only down side is that eventually the adhesive fails and you have to replace it. I'd say I replaced it every 2-3 years.
Guy Buchanan
Ramona, CA
