FLYaDIVE(at)aol.com Guest
Posted: Sat Jun 24, 2006 2:18 pm Post subject: Blue Mountain EFIS -Lite Problem |
Hello my fellow electron chasers:
I have a problem, my doctor already knows that but I thought I would share it
with you.
I just installed a Blue Mountain EFIS-Lite in the panel of an RV-6A.
With the engine OFF and MASTER ON I then turn on the EFIS.
The unit boots normally and the AI screen comes up.
It takes a few seconds and the horizon stabilizes.
[I feel it is not stabilizing SOLID the way a vacuum AI would.]
Here comes the real problem ...
Master ON, EFIS OFF - Normal procedures I start the engine.
All the vacuum gages stabilized.
I then turn ON the EFIS.
The AI NEVER stabilizes there is a slow tumble until I see either nothing but
sky or ground. NEVER STABILIZING!
Has anyone ever run across this problem and if so what was the cause and cure?
It has been suggested that I perform two (2) operations:
1 - Upgrade the Software from Ver 2.21 to Ver 2.64
2 - Hook up the keyboard and do a Warm System reboot from the keyboard
What are your thoughts? Does this sound like a cure? Of course the software
upgrade is required and will be done.
Barry
"Chop'd Liver"
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sat Jun 24, 2006 5:21 pm Post subject: Blue Mountain EFIS -Lite Problem |
On Jun 24, 2006, at 6:13 PM, FLYaDIVE(at)aol.com wrote:
| Quote: | Here comes the real problem ...
nothing but
Sounds exceedingly broken to me.
| Quote: | Has anyone ever run across this problem and if so what was the
cause and cure?
the software
You know, IMHO no gyro device should ever require the pilot to do
anything to make it work right. It should come up and work flawlessly
from the moment you turn it on and it erects. But that is just my
opinion.
It is not the hardware that scares me with glass -- it is the software.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
bferrell(at)123mail.net Guest
Posted: Sat Jun 24, 2006 5:38 pm Post subject: Blue Mountain EFIS -Lite Problem |
Barry,
I'd call Greg and the guys and get their opinion. First, the older BMA
products need a good GPS fix to get an attitude solution, but this doesn't
sound like your problem. It sounds more likely to me that your magnetometer
is being affected by a large current near it, which I believe can also cause
a poor attitude solution. Does your heading indication wander as well? I
have the E/1, and I've never had this sort of issue.
Brett
Posted: Sat Jun 24, 2006 7:21 pm Post subject: Blue Mountain EFIS -Lite Problem |
In a message dated 6/24/06 9:43:10 PM Eastern Daylight Time,
bferrell(at)123mail.net writes:
| Quote: | Barry,
magnetometer
cause
Brett
Brett:
I have tried the unit with and without the magnetometer hooked up. Same
results! The BALL does not wander and the DG is stable. I do have to make a
better mount for the magnetometer, yet I don't believe that is the problem or what
is affecting the AI part of the unit.
At BMA, Larry suggested two steps:
1 - Upgrade the software and
2 - Do the warm reboot with the keyboard.
Then if it still does not erect call him back.
Barry
"Chop'd Liver"
