Lynn Mattison? Sport Aviation
Pat Reilly
PostPosted: Fri Jun 20, 2014 1:30 pm    Post subject: Lynn Mattison? Sport Aviation Reply with quote
Lynn, Turned off my computer and finally opened up June issue of Sport Aviation to pg 11. Low and behold there you are gassing up your Kitfox. I guess that's you. It is definitely your Kitfox. No byline to ID you. But it's you. You'd better call your lawyer! EAA publishing a picture without approval.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Lynn Matteson
PostPosted: Fri Jun 20, 2014 4:55 pm    Post subject: Lynn Mattison? Sport Aviation Reply with quote
Hi Pat...
I've been trying to figure out where that shot was taken. Definitely
not Oshkosh, as you cannot refuel yourself up there. I don't
recognize the background scenery. Lawyer, hell, I need all the
publicity I can get. : ) It had to be an early photo, as I was
running the original Sensenich prop...before the black Sensenich, and
WAY before the current Prince prop.
Re the approval, I think the law reads that you don't need approval
if the subject of the photo is doing ordinary things in a public
place. At least that's the code that I went by when I was a photog.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1575 hrs... (since 3-27-2006)
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
