flying-nut(at)cfl.rr.com Guest
Posted: Sat Jun 21, 2014 7:13 pm Post subject: plastic protector |
I'm getting ready to install the windshield and am looking for a product
to protect the plastic while I work near the edges. I have seen a
paint-on or spray-on latex that will peel off when the installation is
done .... but I can't remember what the product name is. Any ideas???
Linn
dhmoose
Posted: Sat Jun 21, 2014 11:20 pm Post subject: Re: plastic protector |
Not the answer you were looking for, but...I used some 20 mil pipe tape to outline the area that I wanted the fiberglass to end on the windscreen. 20 mil tape is very thick and durable which allowed me to sand down to it without fear of hitting the plexi. The rest of the windscreen was just covered with the plastic it came with from Desser...but that plastic is just there to prevent the random bit of epoxy or other debris from touching or damaging it.
Learned the tape trick from Wally at Synergy Air.
D
_________________ David Halmos
RV-10
Flying!
Portland, OR |
davidsoutpost(at)comcast. Guest
Posted: Sun Jun 22, 2014 2:58 am Post subject: plastic protector |
You are probably thiking to this stuff referred to as "spraylat".
http://www.aircraftspruce.com/catalog/cspages/discoat4220plexiglass1.php?clickkey=9996
It's commonly used in the Rutan based construction of the Long EZ's and Cozy's but most folks have moved away from it due to the difficulty in removal when everything is done. What we used building the Cozy and what I used on my -10 was common 3/4" wide electrical tape. It stretches to form curves very easily and peels off leaving very little to no residue. Do about 2 width's of tape wide, overlapping an 1/8", then follow up with a layer of duct tape on top of that. Gorilla tape works very well and provides a good margin of safety from marking up the glass from sanding and other cutting tools. The remainder of the transparency can be covered in heavy 10 mill plastic.
Sent: Saturday, June 21, 2014 11:12:00 PM
Subject: plastic protector
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com>
done .... but I can't remember what the product name is. = &==
Posted: Sun Jun 22, 2014 4:18 am Post subject: plastic protector |
Thanks David! I thought it was 'Spraylat' but Bing coughed up a paint company .... and I just couldn't find it. The search engine in ACS couldn't find anything either ..... used a bunch of keywords. I'll probably do your suggestion. Thanks.
Linn
On 6/22/2014 6:57 AM, David Clifford wrote:
[quote] You are probably thiking to this stuff referred to as "spraylat".
From: "Linn Walters" <flying-nut(at)cfl.rr.com> (flying-nut(at)cfl.rr.com)
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com> (flying-nut(at)cfl.rr.com)
Checked by AVG - www.avg.com
06/21/14 [b]
johngoodman
Posted: Tue Jun 24, 2014 5:00 am Post subject: Re: plastic protector |
I used it, and really liked it. You need to put multiple coats on, so that it will peel off later. I just painted it on with a brush. I can't think of the name, but I got it from Aircraft Spruce. It comes in a quart plastic bottle, and it's blue in color. I also have an identical bottle of mould release, that is green in color - they seem to be identical.
Looking on the AC site, I see two products that it might be:
Plastiease 512B, or PVA Release Film.
John
_________________ #40572 Phase One complete in 2011 |
