Jacking up the RV8 using a hole drilled in the U807 wheel p
rv8builder
PostPosted: Mon Jun 30, 2014 12:37 pm    Post subject: Jacking up the RV8 using a hole drilled in the U807 wheel p Reply with quote
I am not sure that the U807 is stong enough to support the weight of the aircraft and fuel.  I am not an engineer nor have I played one on TV.  Just food for thought..
Dale
On Sat, Jun 28, 2014 at 6:39 PM, Vincent Himsl <vshimsl(at)live.com (vshimsl(at)live.com)> wrote:
[quote] A couple of years ago, while at Felts Field, another RV8 builder suggested I drill a hole in my U807 wheel pant mounting flange to access the gear leg recess. I could then insert a bolt into the hole and use a bottle jack to lift my wheel to change the tire.
A slick idea I mentally filed away until, of course, I forgot most everything he told me.
If you've tried this idea, I would appreciate the details.
VinceH
RV8432 - Flying
Yes I really should finish the wheel pants
et="_blank">http://www.matronics.com/Navigator?RV8-List
tp://forums.matronics.com
Dale
