Auto Fuel
BobbyPaulk(at)comcast.net
PostPosted: Thu Jul 03, 2014 1:21 pm    Post subject: Auto Fuel Reply with quote
Guys
I have been using Marine fuel ( automotive boosted to 92 octane ) for years and boosting it to 93 octane.
I just read an item from Jabiru USA that says 91 octane is O.K.
Check it out.
[url=http://www.usjabiru.com/JabiruEngines_D0PT.html][/url]http://www.usjabiru.com/JabiruEngines_D0PT.html
I was very careful adapting from 100 LL to the 93 octane marine fuel by putting the 93 in one tank and taking off on the other with 100LL. Loading the engine gradually to make sure it was not detonating. I was wondering if any one has been using 91 Octane NON ethanol auto fuel with good results. I used 93 Octane ethanol for a while but got concerned about how long it would stay in the tank before breaking down or collecting water. I have had bad experiences with ethanol in lawn equipment that is not used regularly and do not use it any more.
Bobby ( age 76 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 217 hrs.
wb2ssj(at)rochester.rr.co
PostPosted: Thu Jul 03, 2014 2:18 pm    Post subject: Auto Fuel Reply with quote
I have used 91 octane non ethanol for 12 years now and have it both in my 6 cylinder lightning and my 4 cylinder jabiru 0 problems.Tex
Sent on a Virgin Mobile Samsung Galaxy S® III
<div>-------- Original message --------</div><div>From: BobbyPaulk(at)comcast.net </div><div>Date:07/03/2014 5:20 PM (GMT-05:00) </div><div>To: "Server, JabiruEngine-List Digest" <jabiruengine-list(at)matronics.com> </div><div>Subject: JabiruEngine-List: Auto Fuel </div><div>
</div>Guys
Check it out.
Bobby ( age 76 )
Zodiac 601 XL "B"
BARRY CHECK 6
PostPosted: Thu Jul 03, 2014 2:23 pm    Post subject: Auto Fuel Reply with quote
Bobby:
There is a huge amount of information on running MoGas Vs AvGas. MoGas wins hands down.
The limiting factor for the octane rating is the compression ratio of the engine. Cars have compression ratios in the range of 8.5:1 to 12:1. And they all use 92 octane AND that rating is obtained by the (R1+R2)/2 method - WHICH is not as good as using a Knock Engine. AND - Just think of it all those cars can run on 92 octane!!! There is NO reason for you to spend the extra money trying to obtain an increase of ONE (1) octane number ESPECIALLY since you have NO way of proving that you are even getting that much!
I have been using 91 octane on a 180+ HP Lycoming O-360 engine for years without a single problem. Mater of fact... The spark plugs LQQK GREAT, no lead fouling. Compression ratio: 9.5:1... Before Mods, I would guess 10.5:1 but I never did the math. I also have been running MoGas on an O-320 150+ HP HC for years and can say the same thing... UNTIL New Jersey went the way of ethanol gas... Now I switched to AvGas - NOT a DROP of ethanol free gas is available in this lousy Damn-O-Cratic state of NJ!
Barry
On Thu, Jul 3, 2014 at 5:20 PM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
[quote]Guys
Check it out.
Bobby ( age 76 )
Zodiac 601 XL "B"
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
UK Clive
PostPosted: Fri Jul 04, 2014 2:18 am    Post subject: Auto Fuel Reply with quote
I tried 91 octane mogas 50-50 with 94 octane mogas in my 2200, ran like a bag of spanners, drained it out and put it in the car and put fresh 94 and she was sweet again. 91 octane is too low for Jabs, certainly in Uk, 91 is for Tiger Moths etc, really low compression, though it can be variable, I know one field that ave switched back to Avgas because of that.
Regards Clive
On 3 Jul 2014, at 23:22, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]Bobby:
Barry
Guys
Check it out.
Bobby ( age 76 )
Zodiac 601 XL "B"
ist" target="_blank">[url=http://www.matronics.com/Navigator?JabiruEngine-List]http://www.matronics.com/Navigator?JabiruEngine-List
BARRY CHECK 6
PostPosted: Fri Jul 04, 2014 3:15 am    Post subject: Auto Fuel Reply with quote
Clive:
Tiger Moth (very old plane/engine) and many of the 1970 planes were designed to run on 80 Octane. That is 6.5:1 compression up to 8.5:1 compression. BUT! That is 80 octane as proven/tested by an anti-knock engine. Not a home-brew mixing of gas, or even the MoGas divide by two (2) method. The question is: What is the compression ratio of the Jab and is yours equal to that or any higher? On the O-320 the case halves have been machined down 0.010" each (total of 0.020") so the compression ratio has been increased to above the published 9.5:1 ratio.
Barry
On Fri, Jul 4, 2014 at 6:17 AM, Clive james <zcrj90(at)yahoo.co.uk (zcrj90(at)yahoo.co.uk)> wrote:
[quote]I tried 91 octane mogas 50-50 with 94 octane mogas in my 2200, ran like a bag of spanners, drained it out and put it in the car and put fresh 94 and she was sweet again. 91 octane is too low for Jabs, certainly in Uk, 91 is for Tiger Moths etc, really low compression, though it can be variable, I know one field that ave switched back to Avgas because of that.
Regards Clive
matronics(at)rtist.nl
PostPosted: Fri Jul 04, 2014 3:39 am    Post subject: Auto Fuel Reply with quote
Why do you think Jabiru has increased the barrel size over time from 106mm to 106.5, then 107 and now 107.5mm?
On 7/4/2014 1:15 PM, FLYaDIVE wrote:
[quote] Clive:
Barry
Regards Clive
BARRY CHECK 6
PostPosted: Fri Jul 04, 2014 3:51 am    Post subject: Auto Fuel Reply with quote
I don't know! Did they ever publish the reason why?
Bigger bore equals:
Lower compression
More volume
More HP
Maybe better burning/ignition properties?
Maybe a less expensive set of rings or piston?
Maybe easier starts
Maybe lower CHT's
So, what are the answers?
Barry
On Fri, Jul 4, 2014 at 7:39 AM, Rob Turk <matronics(at)rtist.nl (matronics(at)rtist.nl)> wrote:
[quote] Why do you think Jabiru has increased the barrel size over time from 106mm to 106.5, then 107 and now 107.5mm?
Clive:
Barry
Regards Clive
Wayne Lenox
PostPosted: Fri Jul 04, 2014 5:21 pm    Post subject: Auto Fuel Reply with quote
On Jul 3, 2014, at 6:17 PM, wb2ssj <wb2ssj(at)rochester.rr.com (wb2ssj(at)rochester.rr.com)> wrote:
[quote]I have used 91 octane non ethanol for 12 years now and have it both in my 6 cylinder lightning and my 4 cylinder jabiru 0 problems.Tex
From: BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
Guys
Check it out.
Bobby ( age 76 )
Zodiac 601 XL "B"
st">http://www.matronics.com/Navigator?JabiruEngine-List
cs.com
matronics.com/contribution
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž­8^%¦â®á'‚)Þ.+-f¢”Z+ºe,zØ^1«k¢xœ°¸¬´Wš¶êÞ°Ö¯Š­¢»hnº0±ëazf§È¸¬¶ëb–+bzË.r¬.+-RÒ¹»®*mŠ‰À­Èb½äžj·!Œ'–†ì6²º0±à¡jÑ(at)(at)øh¶‹!j·šÙ®r®r¨­æ¡­çá¶Úÿ 0™«k¢xœ±Ê&üÖ¯Š­¢²Zn*îx"ââ²Øm¶Ÿÿà &jÚèž',r‰¿5«â«h¬–›Š»„ž§x¸¬·öŒ4N4€’X(at)E9 I&¦z Þj×(ž×§µ©l¡«ÚŠV›•ëâjØ^YæÅ¢»¦±¨kyøm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢hm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢oÚ.+- ‰í®&î¶*'YæҊד…©äÊ‹Ÿ¢¼¨º¸êèºË.¦š+´Æ­´:Ú–W‹ŠË(at)vh§jÞ~m§ÿðà š¶º'‰Ë¢oÜ¢{k‰»­Š‰á¶Úÿ 0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨Ÿö¿o÷èžßé­ïÛ¡Ü¿†Ù¥
PostPosted: Fri Jul 04, 2014 10:26 pm    Post subject: Auto Fuel Reply with quote
Jabiru has not to my knowledge published reasons why, but lower compression to make it run on poor quality, low octane fuel is an obvious one. This will be at the expense of HP.
They have made many other changes, and many of them without providing a reason (or when they did, it didn't always make sense).
On 7/4/2014 1:51 PM, FLYaDIVE wrote:
[quote] I don't know! Did they ever publish the reason why?
Bigger bore equals:
Lower compression
More volume
More HP
Maybe easier starts
Maybe lower CHT's
Barry
Clive:
Barry
dwwilt
PostPosted: Sat Jul 05, 2014 3:45 am    Post subject: Auto Fuel Reply with quote
I could be wrong and I have not researched this, but my very poor memory is telling me that the UK and Australian method of calculating octane is different than the formula used for the US. I remember that UK octane of 91 is equivalent to our US octane rating of around 93 or 94. Can anyone verify this? If this is true then the use of mo-gas 91 in the UK is ok, but not in the US. In the US we would have to use 93 or 94 octane fuel.
Me? I use avgas and don't worry about it.
Dennis W. Wilt, Aviation Consultant
Communications, Navigation, and Surveillance Subject Matter Expert
Program and Project Management
757-784-8113
N616DW (Arion Lightning S/N 132)
Dennis
rpf(at)wi.rr.com
PostPosted: Sat Jul 05, 2014 4:09 am    Post subject: Auto Fuel Reply with quote
I believe it’s the other way around (US rating of 91 is equal to UK rating of 94-95). Anyway, have been using 91 octane (we have 100LL and 91 mogas at my airport) for 900 hours now with no problems. It occasionally gets 100LL when I need fuel away from my home airport.
Randy
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Dennis W. Wilt
Sent: Saturday, July 05, 2014 6:45 AM
Subject: Re: Auto Fuel
757-784-8113
