RV-7 wireing questions
PostPosted: Thu Jul 10, 2014 12:47 pm    Post subject: RV-7 wireing questions Reply with quote
At 01:17 PM 7/10/2014, you wrote:
Hey Bob, I have your book Aeroelectric Connection 2005 and I am
building an RV-7. Great book by the way (I am a super beginner). I
am going to use your figure Z-11 generic light aircraft electrical
system diagram for pretty much all of my system but have a few questions.
I want a master switch and an avionics switch on my panel so I can
start my engine before I power up my avionics
Okay, why do you want to do this? No such feature is
suggested on any of the Z-figures . . . the value
for an avionics master switch was poorly perceived
when it was birthed (about 1968). Today, rudimentary
design skills make virtually every appliance
immune to what ever the system might throw at it . . .
including the cranking of engines.
Some readers have proffered the idea that turning
avionics loads off will enhance cranking performance. . .
an idea without foundation in physics for an airplane
with a properly maintained battery. If you're willing
to go flying with a battery that might not get the
engine started if it were presented with a few amps
additional load, then I suggest there's value in
a review of your design goals as they drive risks.
Don't get me wrong, if you WANT any switch in the
airplane for ANY purpose, fine by me. I suggest
there is value in understanding the exactly what
the switch will (or will not) do for you . . .
and how it figures into your assessment of risks.
user9253
PostPosted: Fri Jul 11, 2014 7:24 am    Post subject: Re: RV-7 wireing questions Reply with quote
Z-11 is a good choice. An avionics switch is not recommended because if it fails, all of the avionics stop working. And any switch will eventually fail. I would question the qualifications of anyone who warns about damaging voltage spikes during engine start. Have they written a book on aircraft wiring? Dynon states in their Pilots User Guide for both the D-180 and SkyView that it is OK to have their units powered on during engine start.
The real problem during engine cranking is not voltage spikes, but rather voltage slump, aka brownout. That is an annoyance, not a danger to avionics.
Joe
Joe Gores
kleh(at)dialupatcost.ca
PostPosted: Fri Jul 11, 2014 7:58 am    Post subject: RV-7 wireing questions Reply with quote
About once every 50 engine starts my Gemini ADI (glass stand alone ADI)
will freeze up. The only indication of that before takeoff is that the
gps heading does not change during taxi. For aircraft without brown out
protection, it might be convenient to have a switch of some kind, or an
accessible circuit breaker, to reboot any devices that don't have their
own on-off switch.
Sure the battery master will also do it but I choose not to test the
load dump capability of my internally regulated alternator, or my PM
alternator, by deliberately cycling the master with a running engine. My
John Deer PM regulator does not like load dumps.
Ken
On 11/07/2014 11:24 AM, user9253 wrote:
<fransew(at)gmail.com>
units powered on during engine start. The real problem during engine
brownout. That is an annoyance, not a danger to avionics. Joe
-------- Joe Gores
PostPosted: Fri Jul 11, 2014 12:17 pm    Post subject: RV-7 wireing questions Reply with quote
ADI) will freeze up. The only indication of that before takeoff is
that the gps heading does not change during taxi. For aircraft
without brown out protection, it might be convenient to have a
switch of some kind, or an accessible circuit breaker, to reboot any
devices that don't have their own on-off switch.
The Gemini ADI installation manual does speak
to an ADI Master Switch downstream of a 1A
breaker. This is a very low power consumption
device!
How a bout a miniature, normally closed push button
next to the instrument in series with the power
input that would allow you to do a 'hard' reset?
engine. My John Deer PM regulator does not like load dumps.
Ken
Don't you have positive alternator control?
For a PM alternator, a set of relay contacts
in series with the AC output winding will
offer a way to shut it off without undue
stress.
