Flaperon
jim.gilliatt(at)att.net
PostPosted: Tue Jul 08, 2014 5:29 pm    Post subject: Flaperon Reply with quote
Does anyone have a old, used or otherwise unneeded flaperon. I need it
for the shape of the airfoil in building a wind tunnel.
Jim Gilliatt
markdonahue
PostPosted: Tue Jul 08, 2014 5:57 pm    Post subject: Flaperon Reply with quote
I have a jig that I cut from the drawing that allowed me to clamp to the
flaperon
It is made of wood, 1-1/2 in thick, in two pieces, with the pattern of the
aleron glued on, and then cut out as a clamp with two screw fasteners to
hold the pieces together. I don't know why I saved it, but you can have
it if it helps what it is you are doing.
Mark Donahue
Mark Donahue
rexinator
PostPosted: Wed Jul 09, 2014 9:45 am    Post subject: Flaperon Reply with quote
I bought a damaged Model 2 and I still have a bit of the old
flaperonthat was damaged. If you only need a foot or so section that is
straight I could cut it out and supply that much.
Rex Hefferan
M2/582
Pueblo, CO
it for the shape of the airfoil in building a wind tunnel.
Jim Gilliatt
