crobin(at)skyvantage.com Guest
Posted: Wed Jul 09, 2014 11:29 am Post subject: MGL digital tach on an M-14 |
I just talked to MGL after purchasing an RV-1.... Support there says the P-Lead installation is unreliable, but 'go ahead and try it to see what happens'...
I don't like the 'try it' idea when it comes to airplanes.
Anyone using a digital tach with the P-lead successfully?
What are your settings? (4.5 pulses per rev?)
Did you use the 10k ohm resistor?
thanks in advance.
-Threeper65
dabear
Joined: 21 Jan 2011 Posts: 92 Location: Warrenton, VA
Posted: Wed Jul 09, 2014 11:46 am Post subject: MGL digital tach on an M-14 |
I used the Horizon digital tach on my Housai and M14P directly with no resistor. I used the Horizon on the M14P for over 500 hours. On the Dynon SkyView you need the resistor to get smooth readings, but works flawlessly. I’ve had it on my CJ for over 2.5 years and 250 hours.
I have No experience with the MGL tach.
The correct pulses per rev for the M14P is 2.25.
Bear
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Cory Robin
Sent: Wednesday, July 09, 2014 3:28 PM
To: yak-list(at)matronics.com
Subject: Re: MGL digital tach on an M-14
thanks in advance.
-Threeper65
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 01234567
