jliltd
Posted: Wed Jul 09, 2014 7:29 am Post subject: Jeri |
Jeri,
I am not sure what your computer is trying to run. Script is computer code and could either be good or bad depending on where it came from. If in doubt tell it to "stop". Did you try turning off the computer, leaving it for 1 minute and then starting it again?
Hope that works but let me know if otherwise.
Jim
<div>-------- Original message --------</div><div>From: Jeri Hallberg <jeri.medical(at)hotmail.com> </div><div>Date:07/08/2014 12:04 AM (GMT-07:00) </div><div>To: Jim <jim(at)jimivey.com> </div><div>Subject: Jeri </div><div>
</div>hey
Hi Jimmy!!
The computer at Waldo'S continues to present notices regarding an option to
"RUN" or " STOP" a script.
then I get these little sky blue circles that I assume mean there is some sort of
procedure going on.
Any ideas??
Yes I know it is late and you are probably asleep so if you want to respond great
if not
that's cool too
but responding would be better
using it for browsing..
no research or anything like that
at this time.
Jeri
scdawson(at)gmail.com Guest
Posted: Wed Jul 09, 2014 8:34 am Post subject: Jeri |
Strange thing to be on a Yak list, but what Jeri is describing might be the browser complaining about JavaScript running on a web page. This can get slow for all sorts of reasons, including a bad web page, or low memory resulting in swapping.
Make sure Jeri pulls the prop through a sufficient amount of times also, and check to make sure that there is sufficient pressure .
Shaun
On Wed, Jul 9, 2014 at 8:28 AM, Jim <jim(at)jimivey.com (jim(at)jimivey.com)> wrote:
[quote]Jeri,
Jim
To: Jim
Subject: Jeri
hey
Hi Jimmy!!
procedure going on.
Any ideas??
if not
that's cool too
at this time.
Jeri
