ftyoder(at)yoderbuilt.com Guest
Posted: Thu Jul 17, 2014 2:25 pm Post subject: Engine mounts |
My Cont. IO-240 B Engine mounts are 16 years old and need to be replaced. They are conical, of course. What are the ones I need and does anyone have the instillation instructions, torque?
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
bakerocb
Posted: Thu Jul 17, 2014 8:37 pm Post subject: Engine mounts |
7/17/2014
Hello Tim, I am surprised that you have not had to replace the vibration isolators for your IO-240 B engine mount prior to this. These vibration isolators are rubber or elastomeric material that hardens and sags with age. Replacing these isolators is a bit tricky for several reasons. One reason is that the isolators are very similar / identical to, yet in some respects, quite different than the isolators used for the Continental O-200 engine. I have had a Continental engineer give me false information regarding isolators for the IO-240 B because he assumed that the parts for the O-200 and the IO-240 B were identical in all respects, which they are not.
It would be very helpful if you have the TCM Parts Catalog Form X30623A and can look at Figure 12-4 on page 12-8 of that manual. I’ll try to give you a description of what is on that page using the following Index Numbers from Figure 12-4:
12-4-1 Part Number 638225. Bushing. An elastomeric tube unique to the IO-240 B (Not the same part as used in the O-200, but performs a similar function as Hose, Part number 628555-16 which is Ref No 1 on the Aircraft Spruce page below). Four required. Should be replaced. Expensive. Not readily available. I can give you some purchasing source information after I get out to the hangar on Sat. Also see below**.
http://www.aircraftspruce.com/catalog/eppages/contmountparts.php
12-4-2 Part Number 530626. Seat, Engine Mount. A steel ring. Same part as used in the O-200. Eight required. No need to replace these parts unless damaged or lost – can be used over and over. See Ref No 3 on the above Aircraft Spruce page:
12-4-3 Part Number 530740. Bushing, Engine Mount. An elastomeric cone. Same part as used on the O-200. Eight Required. Should be replaced. Available from Spruce. See Ref No 4 on the above Aircraft Spruce page:
12-4-4 Part Number 530741. Washer, Cup. A cup shaped steel washer. Same part as used on the O-200. Eight required. No need to replace these parts unless damaged or lost – can be used over and over. Available from Spruce. See Ref No 5 on the above Aircraft Spruce page:
12-4-5 Part Number 653695. Spacer, Engine Mount. A steel tube. I don’t know how this part for the IO-240 B compares to Part Number 530627 for the O-200, but it performs the same function. (See Ref No 2 on the Aircraft Spruce page above). Four required. No need to replace these parts unless damaged or lost – can be used over and over.
If the above appears confusing I apologize and blame TCM for mucking this up. Please pay careful attention in order to avoid getting the wrong parts. I’ll write a few words about installation in a separate email.
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
**PS: Here are some sources – I might have a better source at my hangar:
http://www.aircraft-specialties.com/bushing-638225/
http://www.airpowerinc.com/productcart/pc/prodpartsV.asp?searchquery=638225&submit=Search&catID=6&mfgID=TC&subcat=0
http://www.skygeek.com/continental-motors-638225-bushing.html
Sent: Thursday, July 17, 2014 6:25 PM
Subject: Engine mounts
[quote] [b]
Keith.Miller(at)esa.int Guest
Posted: Thu Jul 17, 2014 11:03 pm Post subject: Engine mounts |
OC
at what age / hours did you replace your bushings ? , is there a
recommended time for the replacement , plus is there a TCM bulletin on
this ?
Keith
To: <kis-list(at)matronics.com>, "YODER TIM" <ftyoder(at)yoderbuilt.com>,
Date: 07/18/2014 06:38 AM
Subject: Re: Engine mounts
Sent by: owner-kis-list-server(at)matronics.com
7/17/2014
Figure 12-4:
OC
To: kis-list(at)matronics.com
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
