Is there such a thing as too much proseal?
smittysrv
PostPosted: Mon Jun 26, 2006 3:55 am    Post subject: Is there such a thing as too much proseal? Reply with quote
My father taught me well. "If a little does a good job, a lot has to be better!". I'm concerned that I am putting too much proseal on my tank parts, mostly from fear and paranoia about leaks. Comments welcome!
Smittys RV-9A
SmittysRV.com
Bob Collins
PostPosted: Mon Jun 26, 2006 4:56 am    Post subject: Is there such a thing as too much proseal? Reply with quote
//My father taught me well. "If a little does a good job, a lot has to be
I went through two cans of ProSeal on my tanks because I used the Orndorff
method (ProSeal is cheap, use a LOT). He probably got it from your dad.
Tanks didn't leak. Goal met.
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/
Mark Phillips in TN
PostPosted: Mon Jun 26, 2006 5:27 am    Post subject: Is there such a thing as too much proseal? Reply with quote
In a message dated 6/26/06 7:01:05 AM Central Daylight Time, smitty(at)smittysrv.com writes:
I've heard some builders being concerned about too much proseal adding too much weight- my philosophy is if it starts taking away fuel capacity, you might want to back off a bit...
"Liberal" here is a good thing, regardless of societal leanings.  A few ounces extra vs. hassling with leaks, take yer pick!  Just repeat the mantra: "clean, clean, clean" before slopping the stuff on.
Mark Phillips - N51PW "Mojo" RV-6A, 330 leak-free hours
From The PossumWorks...
jamie(at)jpainter.org
PostPosted: Mon Jun 26, 2006 5:29 am    Post subject: Is there such a thing as too much proseal? Reply with quote
Hi Smitty:
I think the only thing to be concerned about here is at the rear baffle
flange where the tank meets the wing root. If the 9 is similar to the 7
here (I believe it is) try not to add too much proseal in that root area
because it will prevent the tank from sitting down on the spar. There
is very little clearance there.
Jamie
http://rv.jpainter.org
FLYaDIVE(at)aol.com
PostPosted: Mon Jun 26, 2006 5:30 am    Post subject: Is there such a thing as too much proseal? Reply with quote
In a message dated 6/26/06 8:01:05 AM Eastern Daylight Time,
parts,
Well, Daddy was wrong. Follow the directions. You DO want enough to form
fillets BUT you do not want layers.
You do want enough so that when you tighten down the inspection hatches and
set the rivets it squeezes out. But you do not want bulges.
Don't forget there are two versions of ProSeal ... 20 OUNCE and 20 POUND.
The OUNCE version is used to seal inspection hatches. The POUND version is used
to make structural seals. Both versions come in different cure times. I
highly recommend the 2 Hour (SLOW) cure.
Again ... DO NOT LAYER the ProSeal.
Barry
"Chop'd Liver"
