Z13 fusible link, circuit breaker, same circuit?
Bob.Bower(at)hdrinc.com
PostPosted: Mon Jul 21, 2014 12:56 pm    Post subject: Z13 fusible link, circuit breaker, same circuit? Reply with quote
Something puzzles me . . .
Drawing Z-13/8 rev T dated 1/17/2014 shows both a 22AWG fusible link and a 5A circuit breaker between the main bus and terminal 5 of the Bat/Alt DC Power switch. When the Bat/Alt DC Power switch is closed and the alternator is making power, the 5A circuit breaker will open if the crowbar over voltage protection module connected to terminal 4 of the Bat/Alt DC Power switch, senses an over voltage condition and grounds the circuit. This functionality I understand.
The wire between the fusible link and the circuit breaker is called out as 18AWG, thus the four size smaller 22AWG fusible link makes sense to me. Three questions:
<![if !supportLists]>1.   <![endif]>What is the function of the 22AWG fusible link in this circuit?
<![if !supportLists]>2.   <![endif]>Shouldn’t the wire from the 5A circuit breaker to the Bat/Alt DC Power switch and the wire from the Bat/Alt DC Power switch terminal 4 to the voltage regulator terminal A also be 18AWG?
<![if !supportLists]>3.   <![endif]>Alternatively, assuming the 20AWG wire is sufficient to carry the load, shouldn’t all wires in this circuit be 20AWG and the fusible link be 16AWG, i.e. 4 sizes smaller?
Thanks in advance for unpuzzling me.
JOHN TIPTON
PostPosted: Mon Jul 21, 2014 1:49 pm    Post subject: Z13 fusible link, circuit breaker, same circuit? Reply with quote
Just to clarify:
Question 3 : four sizes smaller than 20awg, is 24awg, not 16
----x--O--x----
On 21 Jul 2014, at 09:55 pm, "Bower, Bob" <Bob.Bower(at)hdrinc.com (Bob.Bower(at)hdrinc.com)> wrote:
1.   What is the function of the 22AWG fusible link in this circuit?
2.   Shouldn’t the wire from the 5A circuit breaker to the Bat/Alt DC Power switch and the wire from the Bat/Alt DC Power switch terminal 4 to the voltage regulator terminal A also be 18AWG?
3.   Alternatively, assuming the 20AWG wire is sufficient to carry the load, shouldn’t all wires in this circuit be 20AWG and the fusible link be 16AWG, i.e. 4 sizes smaller?
lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List
//forums.matronics.com
PostPosted: Tue Jul 22, 2014 9:55 am    Post subject: Re: Z13 fusible link, circuit breaker, same circuit? Reply with quote
The wire (if very long) between the main power bus and the circuit breaker needs to be protected against short circuits. A fusible link provides this protection. The circuit breaker does not offer protection because short circuit current in this wire will not pass through the circuit breaker. A fuse can not be used because, in case of over voltage, a fuse will blow before the circuit breaker trips.
Shouldn't the wire from the 5A circuit breaker to the Bat/Alt DC Power switch and the wire from the Bat/Alt DC Power switch terminal 4 to the voltage regulator terminal A also be 18AWG?
No, 20 AWG wire can carry 5 amps allowed by the circuit breaker.
shouldn't all wires in this circuit be 20AWG and the fusible link be 16 AWG, i.e. 4 sizes smaller?
If the fusible link is made from smaller wire, it might mechanically break or it might burn open before the 5 amp breaker trips. So leave it at 22 AWG. The wire attached to the fusible link must be 4 sizes bigger, thus 18 AWG. 20 AWG is adequate downstream from the circuit breaker because it is protected by the circuit breaker.
(I edited my original posting.)
Joe Gores
