Erich_Weaver(at)URSCorp.c Guest
Posted: Sun Jun 25, 2006 8:51 pm Post subject: AMP CPC connector help |
Im looking around for decent quality connectors to use for the multiple
wires that go to the pitch and roll servos on my autopilot - all 22 or 20
awg wires. After a few hours of intense brow furrowing, I finally started
making sense of the voluminous choices on the Mouser web site, but a few
questions remain. I think I have it narrowed down to either the series 1
or series 2 AMP CPC connectors - see
http://www.mouser.com/catalog/626/957.pdf
Series 1 is described as having "size 16" contacts, while series 2 has
"size 20". Not sure what that means - does it matter? Secondly, which (if
any) of the pins and sockets available for the series 1 or series 2
connectors can be crimped using my B&C d-sub crimping tool?
Could someone familiar with the AMP CPC connectors steer me in the right
direction?
thanks
Erich Weaver
This e-mail and any attachments are confidential. If you receive this
message in error or are not the intended recipient, you should not retain,
distribute, disclose or use any of this information and you should destroy
the e-mail and any attachments or copies.
stevea(at)svpal.org Guest
Posted: Sun Jun 25, 2006 10:47 pm Post subject: AMP CPC connector help |
Erich_Weaver(at)URSCorp.com wrote:
| Quote: | Im looking around for decent quality connectors to use for the multiple
awg wires.
| Quote: | I think I have it narrowed down to either the series 1
Looks like the "size 16" contacts are larger than the "size 20"
contacts. Size 20 is described as "high density", meaning more pins per
connector than "standard". More pins per connector means they have to
be smaller. This translates to lower current carrying capacity in high
density connector pins compared connector to standard pins. This may
not be a problem in an autopilot system, since the currents are not
large (given the 20 and 22 awg wires involved). You can find lots more
information by wading through the AMP website, finding the right catalog
section, etc.
| Quote: | Secondly, which (if
Hard to tell without sifting through the appropriate AMP catalog. I
would be surprised if they were compatible with the d-sub tool (used
mine this weekend...works great). There are as many crimp tools out
there as connector contact styles. Few of them are cross compatible,
and a compatible tool is required to produce good crimps.
Some basic questions: Where in the autopilot system will these
connectors be located? Do you need connectors in the system in addition
to the ones on the servos and controllers? If additional connectors are
required, why not use d-subs? (they are cheap, reliable, and you already
have the crimp tool!! )
Steve
jschroeder(at)perigee.net Guest
Posted: Mon Jun 26, 2006 6:19 am Post subject: AMP CPC connector help |
Erich -
Buy the AMP CPC Type 2. Allied is a good source and they no longer have a
min. $ amount per order.
Buy the gold plated pins size 20 pins from either Steinmark or B&C and the
crimper from B&C. Stein may also carry the crimper. We used this combo on
the CPC's for the panel and for the DB9's on the autopilot sevros and DB25
for the Tru Trak box itself.
Piece of cake to get good crimps. The pins are good for 20 - 26 AWG and
although they are a bit more expensive, they are mil-spec and for avionics,
that is what is best.
John Schroeder
Lancair ES - about ready to fly.
