Parts For 500 S
gjgiesler(at)hotmail.com
PostPosted: Fri Jul 25, 2014 10:04 am    Post subject: Parts For 500 S Reply with quote
Help if you can. I need  Rod end bearings for doors on 1974 500 S .
    # 330085-11 Rod Assembly - outboard
   # 330085-13 Rod Assembly - inboard
Two of each if i can find them.     Thanks     Gary Giesler   N500RX
moe-rosspistons(at)hotmai
PostPosted: Fri Jul 25, 2014 7:53 pm    Post subject: Parts For 500 S Reply with quote
Gary,
Which doors?
Moe Mills
N680RR
680F(p)
Subject: Parts For 500 S
Date: Fri, 25 Jul 2014 13:04:35 -0500
st" target="_blank">http://www.matronics.com/Navigator?Commander-List
http://forums.matronics.com
PostPosted: Fri Jul 25, 2014 11:21 pm    Post subject: Parts For 500 S Reply with quote
  Moe ,
    Sorry , I should have been more specific.   They are the main gear door rod end bearings. Where the rod connects to the door to open
and close it. I need at least one set...inboard and outboard. I think this is what the mechanic is describing to me on the phone. My parts
book is there with the plane at the shop. I will have to get a visual on the problem Monday for a better mental picture.
        Thanks   Gary
        N500RX
Subject: RE: Parts For 500 S
Date: Fri, 25 Jul 2014 21:53:07 -0600
Gary,
Which doors?
Moe Mills
N680RR
680F(p)
PostPosted: Sat Jul 26, 2014 5:27 am    Post subject: Parts For 500 S Reply with quote
Gary,
I have a set of main gear doors for a Shrike, however, I believe that the hardware has been removed, and I will not be able to get to them for a few days to check, as I am on vacation.
Moe
Subject: RE: Commander-List: Parts For 500 S
Date: Sat, 26 Jul 2014 02:21:38 -0500
  Moe ,
        Thanks   Gary
        N500RX
Gary,
Which doors?
Moe Mills
N680RR
680F(p)
