50% 100ll 50% Av Gas
rwwende
PostPosted: Wed Jul 30, 2014 11:42 am    Post subject: 50% 100ll 50% Av Gas Reply with quote
Anybody running a 50/50 mix with the IO540?
Kellym
PostPosted: Wed Jul 30, 2014 12:35 pm    Post subject: 50% 100ll 50% Av Gas Reply with quote
I don't think you asked what you meant. 100LL=Avgas. Perhaps you meant
Mogas?
Certainly should be doable with 91 Octane mogas or better IF you have
stock 8.5:1 pistons. Any higher compression ratio pretty much demands
100 octane.
Then there is the issue of finding mogas without ethanol. In most of the
country today that is very difficult because of requirements for air
pollution and renewable fuels mandates. Ethanol creates its own problems
and you would have to plan ahead to have fuel system built to withstand
the ethanol and to deliver enough higher fuel flow to counter the leaner
mixture the ethanol will cause.
http://forums.matronics.com/viewtopic.php?p=427574#427574
Kelly McMullen
KCHD
flysrv10(at)gmail.com
PostPosted: Wed Jul 30, 2014 12:52 pm    Post subject: 50% 100ll 50% Av Gas Reply with quote
I know someone in Florida (famous guy around here). Run 50/50 in his Rv6 for years and finally sold the engine after 3000 hrs without any overhaul and bought another new engine.
He flew the plane almost daily so that might be the reason for the longevity.
I think he took off on avgas and cruised on unleaded. If you need better details, I will have to chase him down as he is a Snowbird living in Florida during the winter month.
Can't promise quick turnaround.
Do not archive.
