byronmfox(at)gmail.com Guest
Posted: Fri Aug 01, 2014 5:28 pm Post subject: MT Prop TBO |
Posted: Fri Aug 01, 2014 8:50 pm Post subject: MT Prop TBO |
Many of us are running MT props on our Yak 50/52s and M-14P converted CJs.
I starting thinking about our MT prop today. So, I went to MT's web site and looked at the listed TBOs.
Scrolled down to page 5 of the TBO PDF file to find the list of MT prop/M-14P combinations. All indicate 1,000 hours or 72 months.
Not a pleasant surprise. We're about 12+ months away albeit with only 500+ hours. Local MT approved prop shop prices the overhaul at $6,100. Aghhh!
Blitz Fox415-307-2405
pilotdog57(at)aol.com Guest
Posted: Fri Aug 01, 2014 9:16 pm Post subject: MT Prop TBO |
Wow- makes one wonder what the requirements are for the 3 blade Whirlwind is in that regard.
Being that we are Experimental there is no legal reason to comply with TBO- but that may not sit well with MT on future service needs.
DZ
Sent from my iPad
On Aug 1, 2014, at 9:49 PM, Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
ist"">http://www.matronics.com/Navigator?Yak-List
//forums.matronics.com
Posted: Mon Aug 04, 2014 10:22 am Post subject: MT Prop TBO |
DZ said: "Being that we are Experimental there is no legal reason to comply with TBO"
I am not totally sure even on a Standard Category aircraft you are "required" to comply with a recommended time between overhaul are you?
That said, Airframe Directives are another story entirely.
If an Experimental Exhibition aircraft has say and ENGINE that is certified, or a PROP that is certified, then those major assemblies do not become "Experimental" simply because they are put on an airplane that is in that category. Let me stick with what I know and say that my UTVA-66 that has a certified Lycoming GSO-480B1J6 engine and a certified Hartzell prop. Both of those pieces are subject to AD's and if an AD is written, then I as the owner must comply with the AD or the INTENT of the AD. As for what "intent" means, let's say I replaced one of the two mags with an approved electronic ignition. If an AD came out on that mag, I would be OK, since I complied with the intent of the AD by replacing the mag under question with something else. So if you put a CERTIFIED prop on an EXPERIMENTAL aircraft, you must comply with all airframe directives for that prop.
This is 99.9% useless information because our M-14 and Housai engines and props were NEVER certified, so the whole kit and ka-boodle of the YAK, CJ, Sukhoi aircraft line is Experimental and everything DZ said concerning our particular aircraft is spot on. I also BELIEVE that the MT-9-260 prop series was never certified, but I am not SURE of that. If they are, then AD compliance is mandatory, but I don't think TBO's are.
Comments from Walt or anyone else with more experience are welcome.
Mark
kregg(at)balancemyprop.co Guest
Posted: Mon Aug 04, 2014 10:33 am Post subject: MT Prop TBO |
If anyone in California is interested in purchasing a new MT prop, I can save you money and I can install and balance it for you also.
Contact me off line
Kregg Victory
Victory Aero
2502 John Montgomery Dr.
San Jose, CA 95148
408-836-5122
www.victoryhangar.com
www.balancemyprop.com
Posted: Mon Aug 04, 2014 10:38 am Post subject: MT Prop TBO |
Good points- maybe some versions of MT Props that we run on our M14Ps are certified because of European regulations?
Don't know if that affects us in the States?
[quote] On Aug 4, 2014, at 11:20 AM, "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil> wrote:
Mark
Posted: Mon Aug 04, 2014 10:45 am Post subject: MT Prop TBO |
Has to be certified in the States for it to matter to us. Europe is its own bag of worms.
Mark
McFly
Joined: 21 May 2012 Posts: 101 Location: Scottsdale, AZ
Posted: Mon Aug 04, 2014 11:02 am Post subject: MT Prop TBO |
Generally speaking:
- AD's are mandatory for all aircraft regardless of certification basis. Some experimental aircraft can be exempted with a letter from the FAA
- Unless an aircraft is used for commercial passenger carrying or rental TBO's (calendar and time) as well as SB's are recommendations only.
- I am not currently aware of any AD's on MT props.
Todd McCutchanT-34A & Yak-50
Cell: (260) 402-1740
E-mail: todd(at)fastaircraft.com (todd(at)fastaircraft.com)
www.fastaircraft.com
On Aug 4, 2014, at 8:20 PM, "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Mark
_________________ Todd McCutchan
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Email: todd@fastaircraft.com
Skype: tmccutchan
Web: www.fastaircraft.com & www.flyams.com |
GeorgeCoy
Posted: Mon Aug 04, 2014 11:06 am Post subject: MT Prop TBO |
There are still some MT3 hubs out there.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Todd McCutchan
Sent: Monday, August 04, 2014 3:01 PM
To: yak-list(at)matronics.com
Subject: Re: MT Prop TBO
Generally speaking:
Todd McCutchan
T-34A & Yak-50
Mark
Posted: Mon Aug 04, 2014 11:17 am Post subject: MT Prop TBO |
Maybe the question that Blitz needs an answer to is how MT would view his future service if he does not comply with TBO?
Sent from my iPad
On Aug 4, 2014, at 12:00 PM, Todd McCutchan <todd(at)fastaircraft.com (todd(at)fastaircraft.com)> wrote:
[quote]Generally speaking:
Mark
McFly
Posted: Mon Aug 04, 2014 12:44 pm Post subject: MT Prop TBO |
In my past experience it makes no difference.
Besides, MT proper is unlikely to be the ones overhauling. An authorizes prop repair shop would be.
Sometimes items well past TBO have much larger repair bills so the shops are usually tickled to see over TBO items.
On Aug 4, 2014, at 9:16 PM, Pilotdog57 <pilotdog57(at)aol.com (pilotdog57(at)aol.com)> wrote:
[quote]Maybe the question that Blitz needs an answer to is how MT would view his future service if he does not comply with TBO?
Sent from my iPad
Mark
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Skype: tmccutchan
Dale
Posted: Mon Aug 04, 2014 6:47 pm Post subject: Re: MT Prop TBO |
When MT blades are overhauled they are only done in Germany from what I understand. The blades are stripped, inspected, repaired, re-glassed, painted and a new stainless edge is installed and your time starts over.. The Hub can be overhauled in the states and all service bulletins are complied with and there are some of those. At overhaul all the seals , bolts and basically anything that get wear or tightened is replaced.
I got the distinct impression that if you needed a repair after TBO that would not happen per a agreement with MT. Same as the Russian MT , No Service at all on those. Someone can correct me but that is what I ran into.
McFly
Posted: Mon Aug 04, 2014 9:42 pm Post subject: MT Prop TBO |
This is very interesting!!!
So an MT prop beyond TBO is just trash then?
I will drop an email to MT to see about a more official word.
On Aug 5, 2014, at 4:47 AM, "Dale" <dale(at)frii.com (dale(at)frii.com)> wrote:
[quote]--> Yak-List message posted by: "Dale" <dale(at)frii.com (dale(at)frii.com)>
http://forums.matronics.com/viewtopic.php?p=427994#427994
p://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator==============================================================================bsp; - List Contribution Web Site -p; -Matt Dralle, List Admin.
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Skype: tmccutchan
jan.mevis(at)informavia.b Guest
Posted: Mon Aug 04, 2014 10:14 pm Post subject: MT Prop TBO |
I have an MT prop that has been serviced by an agent of MT in the UK, no problem, with the full consent of Straubing.
But the RUSSIAN made MT props, that's another story (cfr Richard Goode).
MT Germany refuses to repair or overhaul them because of license fee issues.
BR,
Jan
From: Todd McCutchan <todd(at)fastaircraft.com (todd(at)fastaircraft.com)>
Reply-To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Date: Tuesday 5 August 2014 07:39
Subject: Re: Re: MT Prop TBO
| Quote: | --> Yak-List message posted by: "Dale" <dale(at)frii.com (dale(at)frii.com)>
com
richard.goode(at)russiana Guest
Posted: Tue Aug 05, 2014 4:19 am Post subject: MT Prop TBO |
I will try to set some issues straight:
To make my position clear, I am biased in favour of MT props, firstly
because I sell them and secondly because I really believe they are good. For
me a really important aspect is that they are fully certificated and if you
have had, like me, a propeller failure on a "experimental" propeller you
certainly would never want to have it again!
Then, MT will overhaul any prop of theirs, however old or however much
beyond the TBO.
In terms of the Russian MT props, the situation is simply that MT gave a
licence to Speriot in Russia to make MTV-9 props, on the basis that they
would be given a certain royalty for each propeller produced. In the event,
the Russians only declared every second? third? Propeller that they made, so
clearly saved a huge amount on royalty fees! It took MT a while to realise
what was happening since these Russian props with serial numbers that had
never been declared to MT started coming back to the factory or MT overseas
agents for overhaul.
So MT decided to "black" all these Russian props, which simply means that
you cannot get them overhauled, and since the Russian factory is no longer
in business, owners of these props will end up with quite expensive
ornaments. Because of our relationship with MT they have allowed us to buy
some of these Russian props that they themselves have bought in, but
strictly for non-aviation use, and we have made a number of "wind machines"
with these props and M 14 P engines for film studios.
I have heard excellent reports of the Whirlwind propellers, but I will
always have the basic concern about the lack of certification and the test
program that this implies. Yurgis Kairis had a catastrophic failure when an
entire blade departed from his Whirlwind on his Sukhoi 31. The forces tore
the gearbox from the crankcase; broke most of the engine mounts and a lot of
other frame tubes. Fortunately he was at low altitude with a long runway
ahead. Having said that, I am sure that appropriate modifications were
subsequently made.
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
scdawson(at)gmail.com Guest
Posted: Tue Aug 05, 2014 6:09 am Post subject: MT Prop TBO |
I sort of see the logic in blacklisting the Russian MT props because of the licensing issue, but at this point all that does is punish end consumers who didn't know any better. That's too bad. Plus, they are leaving money on the table. If I were in that situation, with a useless MT prop because it was Russian and beyond TBO, I'd be livid, and there's no chance that I'd go back and pet the dog that bit me. I'd end up going Whirlwind.
They be well suited to put together a program that would allow for overhaul of those props.  Perhaps charge enough to cover the license fee? I'm sure the real scenario is more complicated than that, though...
Shaun
On Tue, Aug 5, 2014 at 5:18 AM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
[quote]--> Yak-List message posted by: "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
beyond the TBO.
subsequently made.
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
 Tel: [url=tel:%2B94%20%280%29%2081%20241%205137]+94 (0) 81 241 5137[/url] (Sri Lanka)
Tel:Â Â [url=tel:%2B44%20%280%29%201544%20340120]+44 (0) 1544 340120[/url]
Fax:Â [url=tel:%2B44%20%280%29%201544%20340129]+44 (0) 1544 340129[/url]
[url=tel:%2B94%20779%20132%20160]+94 779 132 160[/url].
christopherjober(at)gmail Guest
Posted: Tue Aug 05, 2014 6:33 am Post subject: MT Prop TBO |
MT "blacked out" these propellers so now they are screwing their customers. My prop was bought and installed by a MT prop shop in Illinois. MT tried to tell me it shouldn't have been brought into the country. They were trying to blame someone when it was one if their approved service companies that sold and installed it! Now when I try to go back to the same company that installed it, they won't touch it. They're telling me that MT won't allow it. They're using the Russian made excuse to not servicing my prop. They allowed this prop to go to a factory approved center, be installed, then refuse to service it?! What's to stop them from using another excuse next time? I for one will not risk buying another 'single use' prop only to be stuck with a wall ornament!
Chris
On Aug 5, 2014, at 7:18 AM, "Richard Goode" <richard.goode(at)russianaeros.com> wrote:
beyond the TBO.
subsequently made.
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
Posted: Tue Aug 05, 2014 8:19 am Post subject: MT Prop TBO |
Of course, I know nothing about the particular circumstances of your propeller. But, are you saying that an official MT agent sold you this (Russian) propeller; installed it and now won't support it? Or, are you saying that you obtained the propeller and had it installed on your plane by an MT agent? If the first, then I suggest they have a strong responsibility to continue to support it. But I suspect the practicality is the second case, and if so, I would agree with their position. To be specific, did they know what prop it was before installing it?
Then, you are being rather simplistic to think that MT are going to look for reasons not to service your prop – why on earth would they do that, except in this very particular case of removing props from service that were manufactured illegally; did not have MT certification so were, by definition, not legally airworthy.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
Posted: Tue Aug 05, 2014 9:05 am Post subject: MT Prop TBO |
It was purchased from Aircraft Propeller Services, Inc. in Wheeling, IL. They are a MT approved shop listed on the MT website for certified service shops. Needing service I called them and they informed me that even though they sold it, they cannot service it. They knew exactly what it was (Russian) when they sold it. Only now under direction from MT in Florida (corporate USA) they cannot service the prop. They said they use to be able to service them. Now they can not. It's as simple as that.
On Aug 5, 2014, at 11:18 AM, "Richard Goode" <richard.goode(at)russianaeros.com> wrote:
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
