rvanduyn(at)stx.rr.com Guest
Posted: Tue Jul 04, 2006 2:53 pm Post subject: help locating hard points |
I need some help: I am at the point of installing the front seat shoulder harnesses and realized that I cannot locate the hard points referenced on (page 49-02) of the RV-10 plans. The head liner is already installed and the cabin cover is primed covering up the location of the hard points. I sure would appreciate someone measuring the location. This could be accomplished measuring aft of the door and up from the window.
Thanks for your help. Bob
jim(at)CombsFive.Com Guest
Posted: Tue Jul 04, 2006 3:28 pm Post subject: help locating hard points |
The two hard points on my top are 11 1/8 inches behind the
rear edge of the door opening (Measured to the center of the circular area of the hard point).
The hard points are 2 feet apart (center to center).
Another measurement is 5 1/2" up from the rear window lip. although yours may be covered / painted over at this point.
A third measurement is to drop a straight edge back from the two door hinges (on the top). The center of the hard point is 5 1/2" down (perpendicular) from that line.
I don't know if this is going to help or not.
Jim Combs
N312F
40192
