GeoB
				 Posted: Thu Aug 21, 2014 12:43 am    Post subject: capacitor |
				 	  | Quote: | 	 		   Its the large one, 20-25000
 I asked out of curiosity, but I know this value is not a critical thing.
 Greater or lesser will probably work the same except in extreme cases. This
 depends on the current you are pulling and the nature of transient spikes
 (hash, static) you have in your power.
 Those tiny lil pale orange ceramic disks found on computer equipment do the
 same thing. They can be tiny because the current is tiny and the supplied
 power is generally very good. They do have to suppress the tiny spikes
 generated by the opening and closing (cycling) of the electronic gates
 inside the chip.
 The voltage spec is more important. With very dirty power and pulling a lot
 of current you will need a higher voltage. When a spike hits the cap it can
 puncture the insulation and element inside (foil generally) and short it
 out, if it is high enough voltage.  You can test for this by the way a cap
 holds voltage in it. It should be able to hold a given voltage overnight.
 Its hard to measure though! But in the morning if it bumps your meter needle
 then it is probably good. A bad cap potentially could drain a small battery.
 Not something you are likely to see every day.
  	  | Quote: | 	 		   some one furnished earlier says the ground should go straight to the
 battery
 It is very important to have an excellent ground on everything electrical on
 the plane. You can hook the cap to any ground and it will work but for extra
 insurance going to the battery is better. Sometimes extra engine grounding
 pays dividends in a variety of ways too.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
