NowackLinden(at)gmx.de Guest
Posted: Sat Aug 16, 2014 3:09 am Post subject: Gerd`s Panel |
Hi Group,
The panel of D-EGFL, kit 162, is finished, most of the wires are already
connected to their C/B`s.
The pic shows the happy moment when all was bolted on for trial. The 2nd
pic shows the details of the central stick and the newly designed center
panel in the raw with the duplex Andair fuel selector valve. It`s duplex
because it simutaneoulsy switches the feed line and the return line that
the ULPower engines need. All the wires, fuel hoses and pitot/static
tubes go through the halfmoon hole at the bottom and then under the spar
box.
The EFIS is GRT`s Sport SX. The traditional backup instruments are a
must here in Germany as well as the fluid compass.
I will use the same left hand throttle lever and casing as in D-ELIY and
have a 2nd throttle that will go in the hole abv and left of the right
side Aveo air valve. The pushbutton seen blw and right of said hole is
the copilot`s PTT.
The electrical system is a little to complex to describe in a few words,
iI plan to do a little writeup for one of the next newsletters that will
explain all the switches.
Uli and I will join this year`s Arion Open House And Fly-In this
October, we hope to see many of you there!
Gerd
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
IFLYSMODEL(at)AOL.COM Guest
Posted: Sat Aug 16, 2014 5:19 am Post subject: Gerd`s Panel |
Hey Gerd: Looks terrific. I am envious.
Lynn
In a message dated 8/16/2014 7:10:35 A.M. Eastern Daylight Time, NowackLinden(at)gmx.de writes:
box.
the copilot`s PTT.
Gerd
n5pb(at)AOL.COM Guest
Posted: Sat Aug 16, 2014 6:55 am Post subject: Gerd`s Panel |
Gerd,
It certainly looks good. I think you will like the GRT SX. BTW, Does GRT provide the Europe moving map data base and 3-D graphics for that area?
When do you expect the first flight?
I am looking forward to seeing you and Uli again this year at the Lightning home coming.
Thanks for the progress update.
take care,
Bear
n1bzrich(at)AOL.COM Guest
Posted: Sun Aug 17, 2014 4:10 am Post subject: Gerd`s Panel |
Sierra Hotel, Gerd.
Buz
On Aug 16, 2014, at 7:09 AM, Gerd + Uli Nowack <NowackLinden(at)gmx.de> wrote:
Quote: | Hi Group,
The panel of D-EGFL, kit 162, is finished, most of the wires are already connected to their C/B`s.
The pic shows the happy moment when all was bolted on for trial. The 2nd pic shows the details of the central stick and the newly designed center panel in the raw with the duplex Andair fuel selector valve. It`s duplex because it simutaneoulsy switches the feed line and the return line that the ULPower engines need. All the wires, fuel hoses and pitot/static tubes go through the halfmoon hole at the bottom and then under the spar box.
The EFIS is GRT`s Sport SX. The traditional backup instruments are a must here in Germany as well as the fluid compass.
I will use the same left hand throttle lever and casing as in D-ELIY and have a 2nd throttle that will go in the hole abv and left of the right side Aveo air valve. The pushbutton seen blw and right of said hole is the copilot`s PTT.
The electrical system is a little to complex to describe in a few words, iI plan to do a little writeup for one of the next newsletters that will explain all the switches.
Uli and I will join this year`s Arion Open House And Fly-In this October, we hope to see many of you there!
Gerd
<Panel D-EGFL.jpg>
<Center fuel panel.jpg>
dwwilt
Posted: Sun Aug 17, 2014 4:46 am Post subject: Gerd`s Panel |
Gerd,
I will put some of your pictures and write ups in the Newsletter. Looking Good.
Dennis W. Wilt, Aviation Consultant
Wilt Aviation Consulting, LLC
Communications, Navigation, and Surveillance Subject Matter Expert
Program and Project Management
757-784-8113
N616DW (Arion Lightning S/N 132)
_________________ Dennis |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
