		sarg314(at)gmail.com Guest
				 Posted: Fri Aug 22, 2014 7:25 am    Post subject: log book errro |
				When doing my annual this year I checked back on the previous log entries I made for my other annual inspections.  I was amazed to discover that a couple years ago I did not make the standard entry about "i gave inspected... it complies with..." etc.  I just wrote "completed annual inspection".
 Is this really a mistake? Do you need the standard verbiage?
 If it is a mistake, how do I make it right?
 I also keep a separate, unofficial document for each inspection. It's  a long check list of everything I did along with with notes, my signature and certificate number.  Probably has no standing with the FAA, but it exists.
 Tom Sargent
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Aug 22, 2014 7:44 am    Post subject: log book errro |
				On 8/22/2014 11:22 AM, Thomas Sargent       wrote:
       	  | Quote: | 	 		                                          When doing my annual this year I checked back on the               previous log entries I made for my other annual               inspections.  I was amazed to discover that a couple years               ago I did not make the standard entry about "i gave               inspected... it complies with..." etc.  I just wrote               "completed annual inspection".
       | 	       If there was ever a problem ..... the standard verbiage would be     better.  And remember it's not an 'annual', but a 'conditional     inspection'
       | 	       Use the standard verbiage next time.
       | 	       Actually, this is what my FSDO recommended as long as it's kept with     the logbooks .... especially since my 'conditional inspection'     occurs over the year (mostly).  Anything not covered during the year     is covered in Jan ... when my entry in the logbook occurs.  It's     amazing what you do throughout the year making improvements/mods and     doing normal maintenance.
      Linn
                  Tom Sargent
 No virus         found in this message.
          Checked by AVG - www.avg.com
          08/22/14     [b]
				 Posted: Fri Aug 22, 2014 8:07 am    Post subject: log book errro |
				Perhaps I should clarify that the separate document I keep is everything I did during the inspection - what I inspected and what the results were.  It's not a record of oil changes or repairs. Those are in the log book.
 Tom Sargent
		Gary.A.Sobek
				 Posted: Fri Aug 22, 2014 8:10 am    Post subject: log book errro |
				Conditional Inspection?  Where in FAA Orders / Operating Limitations     does it call out Conditional other than for a sale of an aircraft?
      FAA Order 8130.2G       Change 1 calls out a Condition Inspection.  If you look at     your Operating Limitations, it will also.
       	  | Quote: | 	 		  No person must operate this aircraft unless       within the preceding 12 calendar months it has had a condition         inspection performed in accordance with the scope and detail       of 14 CFR part 43, appendix D, or other FAA-approved programs, and       was found to be in a condition for safe operation. As part of the       condition inspection, cockpit instruments must be appropriately       marked and needed placards installed in accordance with 14 CFR §       91.9. In addition, system-essential controls must be in good       condition, securely mounted, clearly marked, and provide for ease       of operation. This inspection will be recorded in the aircraft       logbook and maintenance records.
      Condition inspections must be       recorded in the aircraft logbook and maintenance records showing       the following, or a similarly worded, statement: “I certify that       this aircraft has been inspected on [insert date] in accordance       with the scope and detail of 14 CFR part 43, appendix D, and was       found to be in a condition for safe operation.” The entry will       include the aircraft’s total time-in-service (cycles if       appropriate), and the name, signature, certificate number, and       type of certificate held by the person performing the inspection. |
        Linn
		Kellym
				 Posted: Fri Aug 22, 2014 8:29 am    Post subject: log book errro |
				The easiest fix....do a computer generated labeln sticker with the
 correct language quoted directly from your operating limitations.
 Place the sticker right over the incorrect entry and sign it.
 Experimentals do not get an annual inspection, just a condition
 inspection that occurs annually.
 KellyM
 A&P/IA
  FAA, but it exists.
  Tom Sargent
KCHD |
				 Posted: Fri Aug 22, 2014 8:43 am    Post subject: log book errro |
				Sorry ... typing faster than the brain       works.  Thanks for the heads up.
        Linn
        On 8/22/2014 12:10 PM, Gary A. Sobek wrote:
      [quote]              Conditional Inspection?  Where in FAA Orders / Operating       Limitations does it call out Conditional other than for a sale of       an aircraft?
         	  | Quote: | 	 		                    On 8/22/2014 11:22 AM, Thomas           Sargent wrote:
          Linn
          08/22/14     [b]
		mrobert569(at)hotmail.com Guest
				 Posted: Sat Aug 23, 2014 8:10 am    Post subject: log book errro |
				Tom,
 Don't worry about it. Anybody, including the FAA, will know what you meant. And as soon as you write/wrote a new condition inspection entry, the old one was superseded.
 Mike Robertson
 Retired Das Fed
 Date: Fri, 22 Aug 2014 08:22:28 -0700
 Subject: log book errro
 To: rv-list(at)matronics.com
 Tom Sargent
 get="_blank">http://www.matronics.com/Navigator?RV-List
 http://forums.matronics.com
