Tightening head bolts on Jab 2200, which method is best?
mhubel
PostPosted: Fri Aug 22, 2014 6:36 pm    Post subject: Tightening head bolts on Jab 2200, which method is best? Reply with quote
You might also note that a lot of Jabiru engines will have some head bolts keep moving for up to the first 100 hours. That was my observation. I carefully monitored CHTs and do believe they were kept within limits at all times.
The biggest change was as one would expect in the first few hours but It didn't completely stabilize for a while. Quite different from automotive heads. And generally other aircraft engines don't have head bolts.
[quote]--
Mark Hubelbank
mhubel(at)nemon.com (mhubel(at)nemon.com)
978-443-3955[b]
Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com
