Craymondw(at)aol.com Guest
				 Posted: Wed Aug 27, 2014 6:56 am    Post subject: GL111 heat problems |
				By powder coating and having an additional interior ceramic heat treatment  on the exhaust system you can lower bottom end exhaust temperatures up to  15 degrees.  That bottom engine high temperature is absorbed by the oil  coolers' body, oil lines, oil sump and intake systems. After the above was  done to a home base aircraft, the aircraft's oil became so cool the  mechanic had to install a pilot operated gate to get the oil up to  temperature!!.
  |  | - The Matronics Glasair-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Glasair-List |
