valve springs
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List
Pocono John
PostPosted: Fri Aug 29, 2014 11:24 am    Post subject: valve springs Reply with quote
I have the rocker arms and push rods out. How do I get the intake/exhaust valves? Looks like I need to push the spring down, and knock the retaining washer out…is that correct? Anything else I should do? Thanks!
- The Matronics CorvairEngines-List Email Forum -
http://www.matronics.com/Navigator?CorvairEngines-List
John Cronin
bed(at)mindspring.com
PostPosted: Fri Aug 29, 2014 11:35 am    Post subject: valve springs Reply with quote
Support the valve from the bottom - use a spring compressor to press down the thick washer - then remove the two valve keepers
I assume the head is off the engine?
Barry
Pocono John
PostPosted: Fri Aug 29, 2014 2:39 pm    Post subject: Re: valve springs Reply with quote
Just valve cover is off (of course). About to remove the the head. I think the valves will come off if I just remove the cylinder heads. Thanks!
John Cronin
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List All times are GMT - 8 Hours
