moe-rosspistons(at)hotmai
PostPosted: Sun Aug 31, 2014 4:35 am    Post subject: From: Moe Mills Reply with quote
Hi
http://venturetechnologies.net/living.php?eckayhnx3046fxxrky
moe-rosspistons(at)hotmail.com [quote][b]
lloydsss11(at)MSN.COM
PostPosted: Sun Aug 31, 2014 7:49 am    Post subject: From: Moe Mills Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Mo, how much weight did you lose? Every 6 lbs you lose extends your range by 5 miles in a 500b.
[quote] ----- Original Message -----
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Sent: Sunday, August 31, 2014 8:30 AM
Subject: From: Moe Mills
Hi
moe-rosspistons(at)hotmail.com (moe-rosspistons(at)hotmail.com)
title="http://www.matronics.com/Navigator?Commander-List" href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
PostPosted: Sun Aug 31, 2014 10:32 am    Post subject: From: Moe Mills Reply with quote
Lloyd,
It appears that I have been hacked.� About 30 years ago I�lost about 80 lbs. and my weight has not varied over 5 or 6 pounds since then.
It would be most interesting to look at the data that�compares the gross weight with the fuel burn.� My 680F(p) burns about 55 gallons per hour, and the��maxim gross weight is 8,000 lbs.� Usually the take off weight is around 7,600 lbs, as I most often fly either alone or with one lite passanger.�
Moe Mills
N680RR
680F(p)
Subject: Re: From: Moe Mills
Date: Sun, 31 Aug 2014 11:51:12 -0400
Hi
st" target="_blank">http://www.matronics.com/Navigator?Commander-List
http://forums.matronics.com
PostPosted: Sun Aug 31, 2014 5:37 pm    Post subject: From: Moe Mills Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Sorry about hacker. I rounded out fuel burn on the 500B to about 30 gals / hr at 12000FT , about 200mph. That�s about 1.1 mile per Lb of fuel. hope that provides incentive for maintaining a lean frame. I'm about 198 down from 250 when I bought the commander 24 yrs ago. rgds
To: commander list (commander-list(at)matronics.com)
Sent: Sunday, August 31, 2014 2:31 PM
Subject: RE: From: Moe Mills
Lloyd,
It appears that I have been hacked. About 30 years ago I lost about 80 lbs. and my weight has not varied over 5 or 6 pounds since then.
It would be most interesting to look at the data that compares the gross weight with the fuel burn. My 680F(p) burns about 55 gallons per hour, and the maxim gross weight is 8,000 lbs. Usually the take off weight is around 7,600 lbs, as I most often fly either alone or with one lite passanger.
Moe Mills
N680RR
680F(p)
Hi
