fdombroski
Posted: Tue Sep 02, 2014 1:43 pm Post subject: RV-10 Paint Quantity |
I am ordering paint for the RV-10. Does anyone that used PPG Deltron 2000 know the paint quantity required for the base color and clear coat?
Also the quantity of Epoxy Primer needed?
Many Thanks,
Frank
_________________ Frank Dombroski
Multiple Offender RV-8, 7A, 10 x 2
RV-10 2.0 N46VT 2015
KSMQ Somerset Airport NJ |
Posted: Tue Sep 02, 2014 4:13 pm Post subject: RV-10 Paint Quantity |
I really can't answer the question because I'm just getting ready to
paint the fuselage. I bought a gallon of Grey primer and a gallon of
white from Sherwin Williams Auto Paint. I can buy more as I need it.
I do not want to do base/clear coat ..... I look at all the cars with
peeling clear coat and think "If the best experienced paint shops can't
paint clear coat without it peeling .... what chance do I have of
getting it right???"
Linn
On 9/2/2014 5:43 PM, fdombroski wrote:
Many Thanks,
Frank
Frank Dombroski
RV-10 2.0 N46VT soon to be flying
http://forums.matronics.com/viewtopic.php?p=429872#429872
Checked by AVG - www.avg.com
Posted: Tue Sep 02, 2014 5:38 pm Post subject: RV-10 Paint Quantity |
PPG base/clear coat is very high quality and forgiving to the amateur
painter (like me). I did two planes with this and will do the next one the
same. The first plane is now 10 years after painting and still looks like
the day it came out of the paint booth.
For the RV-10, start with a gallon of PPG DP-40LF primer but you will most
likely need another two quarts. Assuming you will do a primary, secondary
and then some accents in another color, start with a gallon of primary
color, two or three quarts of secondary and one quart of the accent color
(get more as needed). You will need two gallons of clear. You will need
about four gallons of PPG reducer (get the right one for the temperature
that you will be painting). Plan on ~$2500 for materials. I am just 4
miles from a PPG distributor. If you have to order and such then get more
to start.
Use PPG Alumi Prep with ScotchBrite pads, one good coat of primer, two coats
of color, two coats of clear. If you are using a tri coat (like a lot of
metallic reds or pearl yellows) do two coats of base, two coats of pearl (or
candy) and then two coats of clear. Follow the times listed with the
product for flash, recoat, tape and top coat exactly.
Paint with the wings, empennage, ailerons, flaps, doors and cowl off. The
RV-10 is so big your arm will get tired so be prepared. Paint the wings
first as they are the easiest so you get the hang of it. Prep, prime, color
and top coat the wings in one weekend, the cowl and doors the next, then
empennage and control surfaces, and the fuselage last (the hardest part as
it is so big and you get to spend a lot of time on your back).
Attached is a homemade air/water separator that did a very nice job for me.
Note the water drain valve. Fill the tub with water and ice.
Carl
122.09 KB |
5721 Time(s) |
Posted: Tue Sep 02, 2014 6:29 pm Post subject: RV-10 Paint Quantity |
Thanks for the data Carl!
More questions on the water separator ...... which is air in and out?
Describe the stuff at the bottom of the vertical pipe .... and the drain valve ... that's hidden by the tub.
Linn
On 9/2/2014 9:38 PM, Carl Froehlich wrote:
[quote] [quote]PPG base/clear coat is very high quality and forgiving to the amateur painter (like me). I did two planes with this and will do the next one the same. The first plane is now 10 years after painting and still looks like the day it came out of the paint booth. For the RV-10, start with a gallon of PPG DP-40LF primer but you will most likely need another two quarts. Assuming you will do a primary, secondary and then some accents in another color, start with a gallon of primary color, two or three quarts of secondary and one quart of the accent color (get more as needed). You will need two gallons of clear. You will need about four gallons of PPG reducer (get the right one for the temperature that you will be painting). Plan on ~$2500 for materials. I am just 4 miles from a PPG distributor. If you have to order and such then get more to start. Use PPG Alumi Prep with ScotchBrite pads, one good coat of primer, two coats of color, two coats of clear. If you are using a tri coat (like a lot of metallic reds or pearl yellows) do two coats of base, two coats of pearl (or candy) and then two coats of clear. Follow the times listed with the product for flash, recoat, tape and top coat exactly. Paint with the wings, empennage, ailerons, flaps, doors and cowl off. The RV-10 is so big your arm will get tired so be prepared. Paint the wings first as they are the easiest so you get the hang of it. Prep, prime, color and top coat the wings in one weekend, the cowl and doors the next, then empennage and control surfaces, and the fuselage last (the hardest part as it is so big and you get to spend a lot of time on your back). Attached is a homemade air/water separator that did a very nice job for me. Note the water drain valve. Fill the tub with water and ice. Carl --
Posted: Wed Sep 03, 2014 5:53 am Post subject: RV-10 Paint Quantity |
Linn,
There are a lot of ways to do this. This example uses a coil of 3/8” aluminum tubing from Aircraft Spruce and some standard fittings. The coil shape is maintained by three pieces of wood and tie wraps. The air goes in at the top (red hose). The coil ends at a PVC “T” fitting. The opposite side of the “T” fitting connects via PVC fittings, out a hole in the side of the tub and to the brass drain valve. The top of the “T” fitting goes up out of the water where you see the yellow air out hose connected. I also ran the out hose 6 feet or so vertically so any condensed but still entrained water would drain back down into the PVC pipe. I blew the water out of the tub every hour or so. I made some ice blocks from gallon milk jugs and floated about four of them in the water while painting. When not in use empty the tube as the aluminum coil will corrode if left in water.
This water separator was the third in line from my compressor. The first is a 10’ up run of ½” copper pipe, then a standard air filter, then this. Without this finally water separator I got water at the paint gun. With it I was always dry.
Have fun. After painting an RV-10 you will find out why commercial paint shops get so much money for a paint job.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters
Sent: Tuesday, September 02, 2014 10:27 PM
Subject: Re: RV-10 Paint Quantity
Linn
[quote] | Quote: | | PPG base/clear coat is very high quality and forgiving to the amateurpainter (like me). I did two planes with this and will do the next one thesame. The first plane is now 10 years after painting and still looks likethe day it came out of the paint booth. For the RV-10, start with a gallon of PPG DP-40LF primer but you will mostlikely need another two quarts. Assuming you will do a primary, secondaryand then some accents in another color, start with a gallon of primarycolor, two or three quarts of secondary and one quart of the accent color(get more as needed). You will need two gallons of clear. You will needpainter (like me). I did two planes with this and will do the next one the | 0 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 1 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 2 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 3 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 4 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 5 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 6 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 7 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 8 | Quote: | | painter (like me). I did two planes with this and will do the next one the | 9 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 0 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 1 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 2 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 3 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 4 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 5 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 6 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 7 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 8 | Quote: | | same. The first plane is now 10 years after painting and still looks like | 9 | Quote: | | the day it came out of the paint booth. | 0 | Quote: | | the day it came out of the paint booth. | 1 | Quote: | | the day it came out of the paint booth. | 2[quote]--
122.09 KB |
5700 Time(s) |
