A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL
Deems Davis
PostPosted: Tue Jun 27, 2006 4:34 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Garey Wittich wrote:
THIS IS NOT "SPAM", but comes from 600+ hours of
research I did while building my RV-8A.
If it walks like a duck and quacks like a duck it's a Duck!
Deems Davis # 406
Fuse
http://deemsrv10.com/
klwerner(at)comcast.net
PostPosted: Tue Jun 27, 2006 4:43 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Who's up for a DUCK HUNT !   Bring yer shotgun & some beer!
johnwcox(at)pacificnw.com
PostPosted: Tue Jun 27, 2006 5:16 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Maybe I should buy a copy of this duck, convert it to PDF and send it to
Tim for the RV University library. What say the masses? Has someone
already contributed to Garey's retirement fund in the Bahamas?
I am at over 4,000 hours of research and wouldn't consider charging for
personal opinion, even when backed by actual documentation and life
experience.
John - $00.02
GenGrumpy(at)aol.com
PostPosted: Tue Jun 27, 2006 5:27 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
If it isn't copyrighted, then go for it!!
grumpy #40404
In a message dated 6/27/2006 8:17:45 PM Central Standard Time, johnwcox(at)pacificnw.com writes:
--> RV10-List message posted by: "John W. Cox" <johnwcox(at)pacificnw.com>
experience.
John - $00.02
rvbuilder(at)sausen.net
PostPosted: Tue Jun 27, 2006 5:48 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
I know what you mean. I had some a$$ selling a "book" on eBay that
purported to give you all kinds of information on different types of,
and how to build your own, hanger door. His "book" ended up being a
bunch of links to some of the common door manufacturer's websites and an
ad for his design business. At least he honored his 100% satisfaction
guarantee. It was called something like Hanger Door $ecrets and was a
PDF. Ya get what you pay for.
However I can recommend the Paintucation video series. Fairly well
done for low budget.
Michael Sausen
-10 #352 Fuselage
mike(at)learningplanet.co
PostPosted: Tue Jun 27, 2006 5:56 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Here's a painting tip and you can have it for free:
Finish the plane and then take it to a respected paint shop to have
it professionally painted. That's what I did on my RV-9A and it was
worth every penny.
Mike Schipper
RV-10 #576 - Empennage (www.rvten.com)
RV-9A - N63MS - Flying (www.my9a.com)
PostPosted: Tue Jun 27, 2006 6:21 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
That's a beautiful paint scheme on the 9A. What paint was used and are
you willing to state how much it cost?
John Cox - KUAO
PostPosted: Tue Jun 27, 2006 7:23 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
It's JetGlo. The total was around $6200. I think the -10 will be
somewhat higher.
Mike
are
John Cox - KUAO
pdwalter(at)bigpond.net.a
PostPosted: Tue Jun 27, 2006 10:05 pm    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Mike, do you have a photo for the group ?
PostPosted: Wed Jun 28, 2006 5:27 am    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Paul,
We'll see if this goes through.
Mike Schipper
On Jun 28, 2006, at 1:03 AM, Paul Walter wrote:
<pdwalter(at)bigpond.net.au>
 Filesize:  492.63 KB
 Viewed:  262 Time(s)
dennis_mangan(at)msn.com
PostPosted: Wed Jun 28, 2006 8:23 am    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Mike
this picture looks like an airpark in TX. I am heading to TX after Oshkosh to find a good airpark to move onto.
Dennis
 Filesize:  414.25 KB
 Viewed:  237 Time(s)
PostPosted: Wed Jun 28, 2006 9:17 am    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
Dennis,
The picture is at Northwest Regional (52F) in Ft. Worth. You could also check out Hillcrest Airport (7TX4) in Keller or AeroCountry (T31) in McKinney.
Mike
On Jun 28, 2006, at 11:17 AM, dennis mangan wrote:
[quote] Mike
Dennis
