kenryan
Posted: Thu Oct 09, 2014 2:01 pm Post subject: are twisted pairs necessary for RS-232? |
Dynon Skyview uses RS-232 serial communication. Is twisted wire a requirement for RS-232? The installation manual makes no mention, other than for their "Skyview Network" which is separate from the RS-232 found in the harness.
henry(at)pericynthion.org Guest
Posted: Thu Oct 09, 2014 3:13 pm Post subject: are twisted pairs necessary for RS-232? |
Twisted pairs for RS-232 won't accomplish much. If you twist RX and
TX together you'll be actively hurting the signal. It's a
single-ended signal and can't take advantage of the common-mode
rejection provided by a twisted pair.
If you have signal integrity problems with it (and can't use the
differential equivalent RS-422) then shielded cable is probably the
way to go.
Henry
On Thu, Oct 9, 2014 at 3:00 PM, Ken Ryan <keninalaska(at)gmail.com> wrote:
| Quote: | Dynon Skyview uses RS-232 serial communication. Is twisted wire a
harness.
kenryan
Posted: Thu Oct 09, 2014 3:32 pm Post subject: are twisted pairs necessary for RS-232? |
Thanks Henry. My next question was whether or not it would be acceptable to splice the RS-232 wires. Specifically I would like to connect them to one side of a terminal strip, and then resume them from the other side. It sounds like that should not cause any problem?
On Thu, Oct 9, 2014 at 3:12 PM, Henry Hallam <henry(at)pericynthion.org (henry(at)pericynthion.org)> wrote:
[quote]--> AeroElectric-List message posted by: Henry Hallam <henry(at)pericynthion.org (henry(at)pericynthion.org)>
way to go.
Henry
On Thu, Oct 9, 2014 at 3:00 PM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
> harness.
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
Posted: Thu Oct 09, 2014 4:01 pm Post subject: are twisted pairs necessary for RS-232? |
On Thu, Oct 9, 2014 at 4:31 PM, Ken Ryan <keninalaska(at)gmail.com> wrote:
| Quote: | Thanks Henry. My next question was whether or not it would be acceptable to
Yes that should be fine.
