Engine problems
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
ernest(at)flmitigation.co
PostPosted: Thu Oct 23, 2014 2:59 am    Post subject: Engine problems Reply with quote
I have an IO-540 in my rocket that was boosted to 290 hp. I recently
started having problems with it and we can¹t figure out what the problem
is.
The symptoms:
The engine runs fine until you get up to about 1600 RPM, at this point it
starts spitting and sputtering and backfiring continuously.
What we have tried:
We changed the spark plugs and checked the timing. Checked compression
and it is all good.
Has anyone had any experience with this? We can¹t figure it out. We did
find that the fuel pressure going into the spider is 30 psi and coming out
is 0, doesn¹t build pressure just has flow. I am not a mechanic just
relaying what my mechanic has told me so if some of this doesn¹t make
sense that is why.
We are at a loss, any guesses would be appreciated.
Ernest Hale
Manager
701 Market St
Suite 111
St. Augustine, FL 32095
o. 904.821.4322 <tel:904.821.4322>
c. 904.568.1490 <tel:904.224.0357>
f. 904.224.0056 <tel:904.224.0056>
ernest(at)flmitigation.com <mailto:laura(at)flmitigation.com>
www.flmitigation.com <http://www.flmitigation.com/>
On 10/23/14, 3:03 AM, "Rocket-List Digest Server"
<rocket-list(at)matronics.com> wrote:
Today's complete Rocket-List Digest can also be found in either of the
of the Rocket-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapt
er 14-10-22&Archive=Rocket
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapte
Rocket-List Digest Archive
Total Messages Posted Wed 10/22/14: 0
Today's Message Index:
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
hr2pilot(at)aol.com
PostPosted: Thu Oct 23, 2014 6:25 am    Post subject: Engine problems Reply with quote
Injunction survo
is.
The symptoms:
What we have tried:
and it is all good.
sense that is why.
Ernest Hale
Manager
701 Market St
Suite 111
> HTML Version:
> Text Version:
PostPosted: Thu Oct 23, 2014 6:51 am    Post subject: Engine problems Reply with quote
Where is the best place to send the fuel injection servo to be overhauled,
my engine is rate for 290 hp.
Ernest Hale
Manager
701 Market St
Suite 111
On 10/23/14, 10:25 AM, "Hr2pilot" <hr2pilot(at)aol.com> wrote:
Injunction survo
> started having problems with it and we can©öt figure out what the problem
> is.
> The symptoms:
>it
> What we have tried:
> and it is all good.
> Has anyone had any experience with this? We can©öt figure it out. We
>did
>out
> is 0, doesn©öt build pressure just has flow. I am not a mechanic just
> relaying what my mechanic has told me so if some of this doesn©öt make
> sense that is why.
> Thanks,
> Ernest Hale
> Manager
> 701 Market St
> Suite 111
>>formatted
>> HTML Version:
>>pt
>> Text Version:
>>te
hr2pilot(at)aol.com
PostPosted: Thu Oct 23, 2014 7:14 am    Post subject: Engine problems Reply with quote
Airflow performance
Ernest Hale
Manager
701 Market St
Suite 111
> Injunction survo
> Sent from my iPhone
>> is.
>> The symptoms:
>> it
>> What we have tried:
>> and it is all good.
>> did
>> out
>> sense that is why.
>> Thanks,
>> Ernest Hale
>> Manager
>> 701 Market St
>> Suite 111
>>> formatted
>>> HTML Version:
>>> pt
>>> Text Version:
>>> te
stuart(at)stuarthutchison
PostPosted: Thu Oct 23, 2014 1:09 pm    Post subject: Engine problems Reply with quote
I’d have the divider serviced at the same time … if there’s damage to the diaphragm, fuel should be coming out the pin hole at the top with the engine running, but you’d only see it with the cowl off.
Cheers, Stu
F1 Rocket VH-FLY www.mykitlog.com/rockfly
On 24 Oct 2014, at 2:14 am, Hr2pilot <hr2pilot(at)aol.com> wrote:
Airflow performance
> Thanks,
> Ernest Hale
> Manager
> 701 Market St
> Suite 111
>> Injunction survo
>> Sent from my iPhone
>>> is.
>>> The symptoms:
>>> it
>>> What we have tried:
>>> and it is all good.
>>> did
>>> out
>>> sense that is why.
>>> Thanks,
>>> Ernest Hale
>>> Manager
>>> 701 Market St
>>> Suite 111
>>>> formatted
>>>> HTML Version:
>>>> pt
>>>> Text Version:
>>>> te
Lee Logan
PostPosted: Thu Oct 23, 2014 2:23 pm    Post subject: Engine problems Reply with quote
What kind of system is it?  If it's an AirFlow Performance, then send it to Don Rivera at their company headquarters in Spartanburg, SC.
smokyray(at)rocketmail.co
PostPosted: Thu Oct 23, 2014 6:17 pm    Post subject: Engine problems Reply with quote
Ernest,
I agree that your issue is most likely fuel servo related. However comma, I had a similar issue with a Bendix Mag combination on my C4B5. I replaced one mag and installed an Electroair Electronic IGN on the other side. Problem solved.
Might be worth a test next run up...
Smokey
Ernest Hale
Manager
701 Market St
Suite 111
> Injunction survo
> Sent from my iPhone
>> is.
>> The symptoms:
>> it
>> What we have tried:
>> and it is all good.
>> did
>> out
>> sense that is why.
>> Thanks,
>> Ernest Hale
>> Manager
>> 701 Market St
>> Suite 111
>>> formatted
>>> HTML Version:
>>> pt
>>> Text Version:
>>> te
PostPosted: Thu Oct 23, 2014 6:30 pm    Post subject: Engine problems Reply with quote
Ernie,
Forgot to mention one of the issues I found on mine with similar symptoms. Five of my twelve "platinum" plugs tested bad under pressure. I replaced them with Autolite 386 for the EI and REM37BY for the mag. Again, problem solved...
Worth a check...
Smokey
Ernest Hale
Manager
701 Market St
Suite 111
> Injunction survo
> Sent from my iPhone
>> is.
>> The symptoms:
>> it
>> What we have tried:
>> and it is all good.
>> did
>> out
>> sense that is why.
>> Thanks,
>> Ernest Hale
>> Manager
>> 701 Market St
>> Suite 111
>>> formatted
>>> HTML Version:
>>> pt
>>> Text Version:
>>> te
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
