				 Posted: Mon Oct 27, 2014 3:44 pm    Post subject: Brown-out resets at engine start |
				At 10:43 2014-10-27, you wrote:
 Yes, potentially if it is wired correctly.
 The point I was trying to subtly make was that we don't yet have a Z
 figure that incorporates brownout protection (that I am aware of, please
 correct me if this is incorrect), and many people keep asking about this.
    It's been discussed and several options offered for
    years.
    (1) Z-14 where starting is accomplished with one battery . . .
    (2) Any Z-figure with an aux battery auto-switched
    like the original ABMM concept except the battery services
    the e-bus as opposed to ignition systems or . . .
    (3) A simple form of auto-switching is illustrated in Z-8
    offering an aux battery auto-switched through a relay that
    disconnects the battery from the main bus while the starter
    is engaged . . . in this configuration, the e-bus alternate
    feed switch is closed during engine start. Add one relay,
    fuse holder and battery sized to task to any system with
    an e-bus.
    There are probably a half dozen or more other solutions
    that speak to design goals for brown-out protection that
    are simply modification to the existing Z-figures. Mods
    with no impact on design goals that brought the Z-figure
    into existence in the first place.
    My current thinking says the dragon to be tamed is not
    how to switch the battery into service . . . but battery
    selection for minimizing volume, weight and cost of
    ownership. As I mentioned earlier, sand-castles built
    in the lithium sandbox over the past few weeks have
    planted seeds of some ideas.
    The battery needs to be capable of say 5A of delivery
    at 10+ volts for a period of not more than 0.5
    seconds about 50 times a year. It's never depended on
    for standby power, hence never expected to be discharged.
    It also needs to demonstrate a long, "shelf life"
    as a device that spends most of its time open circuit,
    50 hours a year attached to a charger, and never asked
    to deliver more than 50 Joules per discharge/charge
    cycle.
    In this case, the elegant solution is driven more
    strongly by product selection than by architecture.
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
