Dual Alternator Question
jfolkerts1(at)gmail.com
PostPosted: Sun Oct 26, 2014 5:26 am    Post subject: Dual Alternator Question Reply with quote
I’m planning on the Z-12 dual alternator single battery installation. I have a VMC-1000 engine monitor and believe it only displays one alternator output. Can I use a simple switch to add the B&C 20 Amp Vacuum Pad alternator so I can check it periodically or should I add another ammeter? Would the switch create enough resistance to throw off the readings on the display?
Jerry Folkerts
PostPosted: Sun Oct 26, 2014 8:46 am    Post subject: Dual Alternator Question Reply with quote
At 08:25 2014-10-26, you wrote:
I'm planning on the Z-12 dual alternator single battery
If the VM1000 uses a hall-effect transducer, run BOTH
B-leads through the same transducer. The display will
show alternator load for the device presently in service.
However, since the SD-20 is a stand-by alternator fitted
with a dedicated hall-effect load sensing and indication
system, bringing alternator load numbers to the panel
offers no in formation of use to the pilot while in
flight.
RV7ASask
PostPosted: Sun Oct 26, 2014 4:16 pm    Post subject: Re: Dual Alternator Question Reply with quote
I am operating a Z12 electrical system in my RV7A and have been very pleased, 200+ hours. The aircraft has recently been certified IFR. It has a Dynon Skyview and a simple switch on the panel to show volts and amps of the alternator selected. Lights on the panel indicate the status of the two alternators.
David Lamb
