rvdave
Posted: Wed Oct 29, 2014 4:51 pm Post subject: Fwf braded stainless |
Do the braided stainless lines require the red fire sleeve or is the SS braid considered fire sleeve? Maybe a dumb question-it's been a long day..
_________________ Dave Ford
Cadillac, MI |
Posted: Wed Oct 29, 2014 5:06 pm Post subject: Fwf braded stainless |
They should have fire sleeve. The braiding is not a fire protection.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Oct 29, 2014, at 8:51 PM, rvdave <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=432521#432521
flying-nut(at)cfl.rr.com Guest
Posted: Wed Oct 29, 2014 5:11 pm Post subject: Fwf braded stainless |
"require" is such a strong word.
I'd put the firesleeve on the SS braided hoses. Actually, all the
hoses. The SS braid only slows down the heat deterioration a little .....
Linn
On 10/29/2014 8:51 PM, rvdave wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
Checked by AVG - www.avg.com
n801bh(at)netzero.com Guest
Posted: Wed Oct 29, 2014 5:18 pm Post subject: Fwf braded stainless |
If you have a under cowling fire hot enough to burn through Stainless Steel braiding.. You have BIGGER problems to deal with.. IMHO..
Ben Haas
N801BH
www.haaspowerair.com
Posted: Wed Oct 29, 2014 5:30 pm Post subject: Fwf braded stainless |
If the stainless was solid, I'd agree, but it's not. The braid is for strength. The fire sleeve is to keep the heat away from the line as long as possible.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Oct 29, 2014, at 9:13 PM, Ben <n801bh(at)netzero.com (n801bh(at)netzero.com)> wrote:
[quote]If you have a under cowling fire hot enough to burn through Stainless Steel braiding.. You have BIGGER problems to deal with.. IMHO..
Ben Haas
N801BH
Posted: Wed Oct 29, 2014 5:34 pm Post subject: Fwf braded stainless |
The SS braid is there for pressure and abrasion resistance. You don't have to burn through the braid .... just get it hot enough to melt the inner lining. That delay with firesleeve may be the difference between having a fire and feeding it more fuel. I would want to delay the decision of whether to burn to death or jump as long as possible.
Linn
On 10/29/2014 9:13 PM, Ben wrote:
[quote] If you have a under cowling fire hot enough to burn through Stainless Steel braiding.. You have BIGGER problems to deal with.. IMHO..
Ben Haas
N801BH
Kelly McMullen
Posted: Wed Oct 29, 2014 6:32 pm Post subject: Fwf braded stainless |
There is no requirement for firesleeve...for years none of Van's supplied hoses had any firesleeve. I guess some of the fuel lines do now. Vans hoses have unprotected SS braid on outside, which is very abrasive to anything it vibrates against. If you haven't already guessed, also the cheapest choice.
However, using firesleeve gives you and the hose inside protection from heat as well ad reducing the fire risk. Best is integral firesleeve hose, but takes a hose shop special equipment to make them, and cost is 10-15% higher than conventional hose with firesleeve
On Wed, Oct 29, 2014 at 5:51 PM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
target="_blank">http://www.matronics.com/Navigator?RV10-List
">http://forums.matronics.com
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
johngoodman
Posted: Thu Oct 30, 2014 4:07 am Post subject: Re: Fwf braded stainless |
Ask your DAR... that will be the final decider.
_________________ #40572 Phase One complete in 2011 |
Lenny Iszak
Posted: Thu Oct 30, 2014 4:16 am Post subject: Re: Fwf braded stainless |
Here's a great resource I used to get integral firesleeve hoses.
http://nerv10.com/wcurtis/20Engine/hose.html
Lenny
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Posted: Thu Oct 30, 2014 4:39 am Post subject: Fwf braded stainless |
I did that. Years ago. Answer was "I don't care". I suspect that most
of them don't.
From observations of inspections on others airplanes, there are DARs
that 'might' recognize the basic shape, look at the workmanship and sign
the necessary documents. Then there are those that have their own
personal hot buttons ..... things they look for and want to see.
IMHO leaving off the firesleeve is like flying with 1/4 tank of gas. If
you ever need it (have a engine compartment fire) you'll wish the
firesleeve was there. If you ever run most of that 1/4 tank of gas out
and are still not on the ground .... you'll wish you had filled the tank up.
My question is "why not use the firesleeve". Weight and cost are the
only things I can think of and in the scheme of things .... they're
negligible.
Now I'll pass on a trick that was taught to me:
Cut the firesleeve to length and insert one end of the hose a little way
into the firesleeve.
Stick your blow gun into the other end of the firesleeve and inflate
it. It'll slide on the hose real easy.
Coat the raw ends of the firesleeve with red high temp silicone to keep
oil and other liquids out.
I have one of those nifty tools to make clamps out of safety wire and I
use that. You can also whip the ends of the firesleeve (look for
'whipping rope' but be careful ... other kinds of whipping are out there
) and cover with the red silicone.
Linn
On 10/30/2014 8:07 AM, johngoodman wrote:
Posted: Thu Oct 30, 2014 4:49 am Post subject: Fwf braded stainless |
Sorry .... left out that you need to plug one end of the hose.
Linn
On 10/30/2014 8:37 AM, Linn Walters wrote:
most of them don't.
sign the necessary documents. Then there are those that have their
own personal hot buttons ..... things they look for and want to see.
If you ever need it (have a engine compartment fire) you'll wish the
out and are still not on the ground .... you'll wish you had filled
the tank up.
negligible.
way into the firesleeve.
keep oil and other liquids out.
I use that. You can also whip the ends of the firesleeve (look for
there ) and cover with the red silicone.
Linn
> <johngoodman(at)earthlink.net>
> http://forums.matronics.com/viewtopic.php?p=432538#432538
> No virus found in this message.
Kellym
Posted: Thu Oct 30, 2014 6:13 am Post subject: Fwf braded stainless |
While I suppose a DAR could refuse to approve an aircraft that didn't
meet his standards,
they are not in the business of reg writing. If they start requiring
stuff that isn't in regs, they will find their clientele diminished.
While firesleeve hoses in the engine compartment is a "best practice",
I've seen nothing to make it a requirement.
I can assure you that the hoses Van's supplied for my FWF kit are not
firesleeved, neither oil nor fuel. They are the straight SS braided
hoses. Van's isn't in the habit of supplying stuff that DARs will balk
at approving.
KCHD |
Kellym
Posted: Thu Oct 30, 2014 6:25 am Post subject: Fwf braded stainless |
Unfortunately Van's leaves you with the options of knowing upfront that
some of their hoses are not firesleeved(used to be all).
If you know that and delete them from your FWF kit, the cost difference
will be small. However, if you believed they had already changed to
firesleeved hoses when they had not, for example was the case when I
ordered, then I have choice of sending them back for diminished refund,
or just buying the hoses desired or using what came in the kit. Just one
of many cases where you can spend time, energy and money changing the
kit or you can proceed towards getting the kit built. So far, in 40 yrs,
I have been fortunate enough to catch leaks before flight and have not
had any engine fire beyond a cold start flooded poof that was contained
by continued cranking. My last engine overhaul on my certified Mooney
saw all integral firesleeve hoses installed, and I like them a lot.
On 10/30/2014 5:37 AM, Linn Walters wrote:
negligible.
KCHD |
Posted: Thu Oct 30, 2014 7:19 am Post subject: Fwf braded stainless |
I didn't have the option of adding/deleting since I bought my kit from
another builder. However, I think originally the raw SS hoses was a way
to keep the costs down and give builders the option of using firesleeve
(http://www.aircraft-spruce.com/catalog/appages/stratofs.php?clickkey=4409
.... there are others)
or not. The integral firesleeve (IMHO) makes the hose stiffer so I like
the stratoflex better anyway. I also make my own hoses (that didn't
come in the kit) so the integral firesleeve isn't practical for them.
Also, I cut the Vans hose from pump to servo to insert my fuel flow
sender .... and the liner was a purplish teflon that wasn't the same
size as the white. The fittings were crimped on and the standard JIC
fittings wouldn't fit. My local hydraulics place couldn't make anything
fit either.
BTW, that hose had the stratoflex firesleeve.
Linn
On 10/30/2014 10:22 AM, Kelly McMullen wrote:
that some of their hoses are not firesleeved(used to be all).
difference will be small. However, if you believed they had already
changed to firesleeved hoses when they had not, for example was the
case when I ordered, then I have choice of sending them back for
diminished refund, or just buying the hoses desired or using what came
in the kit. Just one of many cases where you can spend time, energy
and money changing the kit or you can proceed towards getting the kit
built. So far, in 40 yrs, I have been fortunate enough to catch leaks
before flight and have not had any engine fire beyond a cold start
flooded poof that was contained by continued cranking. My last engine
overhaul on my certified Mooney saw all integral firesleeve hoses
> negligible.
Kelly McMullen
Posted: Thu Oct 30, 2014 11:09 am Post subject: Fwf braded stainless |
I disagree about integral firesleeve being stiffer. It is if anything more flexible than standard hose, especially after the firesleeve is installed, and it is smaller diameter which makes a cleaner fit. Just my experience in 30 yrs of working on planes.
On Thu, Oct 30, 2014 at 8:17 AM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote]--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
I didn't have the option of adding/deleting since I bought my kit from another builder. However, I think originally the raw SS hoses was a way to keep the costs down and give builders the option of using firesleeve
(http://www.aircraft-spruce.com/catalog/appages/stratofs.php?clickkey=4409 ..... there are others)
or not. The integral firesleeve (IMHO) makes the hose stiffer so I like the stratoflex better anyway. I also make my own hoses (that didn't come in the kit) so the integral firesleeve isn't practical for them.
Also, I cut the Vans hose from pump to servo to insert my fuel flow sender ... and the liner was a purplish teflon that wasn't the same size as the white. The fittings were crimped on and the standard JIC fittings wouldn't fit. My local hydraulics place couldn't make anything fit either.
Linn
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Unfortunately Van's leaves you with the options of knowing upfront that some of their hoses are not firesleeved(used to be all).
If you know that and delete them from your FWF kit, the cost difference will be small. However, if you believed they had already changed to firesleeved hoses when they had not, for example was the case when I ordered, then I have choice of sending them back for diminished refund, or just buying the hoses desired or using what came in the kit. Just one of many cases where you can spend time, energy and money changing the kit or you can proceed towards getting the kit built. So far, in 40 yrs, I have been fortunate enough to catch leaks before flight and have not had any engine fire beyond a cold start flooded poof that was contained by continued cranking. My last engine overhaul on my certified Mooney saw all integral firesleeve hoses installed, and I like them a lot.
| Quote: | --> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
My question is "why not use the firesleeve". Weight and cost are the only things I can think of and in the scheme of things .... they're negligible.
le, List Admin.
KCHD |
