N557XW Flies
joelhaynes
PostPosted: Wed Jun 28, 2006 9:29 am    Post subject: N557XW Flies Reply with quote
AB-DAR George Hanna flew from Colorado to Bozeman in is RV-6 yesterday to do the inspection on my 7A (He is the closest DAR to Montana). Believe it or not the FSDO in Helena needed 3-6 months to do my inspection.  After 5 years and 2 months of building, head scratching and the occasional cursing I said, "Forget that!" So I hired George to fly up and do the deed.  After two hours of poring over the airplane he finally gave up trying to find something wrong.
This morning I proved the point that large sums of cash can make 1070 lbs. of aluminum, fiber glass and steel fly under its own power.  She handled well and a small amount of aileron trim allowed her to fly hands-off.  I have some high oil temps (235) so I definitely need to work on directing better air flow through the cooler.  CHT's stabilized around 400 which is also a little on the high side but it is a new engine running straight mineral oil.  The airplane is equiped with an 0-360-A2A from AeroSport Power and an 85 inch pitch Sensenich cruise prop. Despite the warm temps and 5000 ft field elevation, takeoff performance with the cruise prop was no problem.  I know I need to run it hard the first few hours to seat the rings but because of the higher temps I had throttled back to 2200 to 2300 and was still showing 140 kts on the GPS without gear leg fairings or wheel pants.  After some tweaking under the cowling I'll see if I can run it harder and still keep the temps reasonable.  Any advice on CHT and oil temp contro l is welcome.
Only 39.5 Phase I hours to go before Oshkosh.
Joel Haynes
Bozeman, MT
N557XW Flyin' and Grinnin'
shempdowling2(at)earthlin
PostPosted: Wed Jun 28, 2006 10:07 am    Post subject: N557XW Flies Reply with quote
Alls it takes is about another 100 hours of messing around with your baffling and oil cooler setup to get this fixed!  Dont ask Smile
Shemp/Jeff Dowling
RV-6A, N915JD
295 hours
Chicago/Louisville
jeffpoint
PostPosted: Wed Jun 28, 2006 10:08 am    Post subject: N557XW Flies Reply with quote
Congratulations!
On the oil temp, the first thing I would do (if you haven't already) is
calibrate the oil temp probe in some boiling water, to make sure it is
accurate. Beyond that, we'll need some more details on your cooling
setup to troubleshoot.
Jeff Point
RV-6
Milwaukee
Jeff Point
RV-6
Milwaukee WI
lhelming(at)sigecom.net
PostPosted: Wed Jun 28, 2006 3:54 pm    Post subject: N557XW Flies Reply with quote
Way to go Joel.  Enjoy the flights and your plane.  How is that grin anyway?
You still have a lot of testing work to do during the next 39.5 hours and if you are anything close to average, you will find some small set backs as you progress through the testing.  I hope you do not rush through the 40 hours just putting on hours to just get r done.  Review the EAA materials and you will find lots of test flight stuff if you need to take a look at it.  Best wishes.  ( There is always next year for flying to O when it will be much safer for everyone.)
ON HEAT ISSUE:  I had some debris between the fins on the cylinders near the spark plugs that was not allowing air to pass through easily and had to file/clean this away.
Larry in Indiana
rdhowey(at)telus.net
PostPosted: Wed Jun 28, 2006 7:29 pm    Post subject: N557XW Flies Reply with quote
Congratulations Joel and well done!!!!    Bet that's a great feeling.     Keep us informed on your trials with the cooling.......you have the engine prop combo I'm going to use....
Ralph....8qb   rudder
shirleyh
PostPosted: Thu Jun 29, 2006 2:12 am    Post subject: Re: N557XW Flies Reply with quote
Congratulations, Joel - isn't it a great feeling?! Regarding the cooling - I have an 0-360 in my recently completed RV6 - operating in the warmth of Western Australia. I'm not having any oil cooling problems at the moment - rather the opposite! I installed a larger oil cooler than standard because I expected to be operating in high temps. Now that winter is here I've had to tape over about a third of the cooler to keep temps in the green. What size oil cooler have you installed?
Shirley Harding
RV6 VH ASF Flying 10 hours
crowbotham(at)hotmail.com
PostPosted: Thu Jun 29, 2006 6:40 am    Post subject: N557XW Flies Reply with quote
Joel,
CONGRATULATIONS and WELL DONE !!!
Chuck & Dave Rowbotham
RV-8A
Subject: N557XW Flies
Date: Wed, 28 Jun 2006 13:25:19 -0400
Joel Haynes
Bozeman, MT
davemader(at)bresnan.net
PostPosted: Thu Jun 29, 2006 6:47 am    Post subject: N557XW Flies Reply with quote
Joel,
Congratulations on your first flight!  Just for your info or anybody else in your area, there is a DAR that lives in Greybull, Wyo.  I believe he is the only one in the state of Wyo. But he would be much closer than Colo.
His name is Tim Mikus and I’m sure he’s in the book;.  I had him do my inspection in Jan. and he is a heck of a nice guy and did a good job, I feel.  I also have an RV-6 with 0-360 and Sensenich.  My only complaint is the fact the I can turn it almost 2900 rpm at wide open throttle.  The engine was built up by a guy in Colo. And he “tweaked” it a little bit.  Higher comp pistons, etc.  I think I will leave it as is so I don’t loose my climb performance.   Don’t know what to tell you as far as  temps go, other than 400 is  not bad considering a new engine and mineral oil.  As far as oil temp., maybe the larger Stewart Warner cooler?  They seem to help most guys when they go to it.  Kind of pricey though.  Anyway, congrats and have fun.  Stop in Sheridan sometime and give me a call.
Dave Mader
674-7027
davemader(at)bresnan.net (davemader(at)bresnan.net)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of joelrhaynes(at)aol.com
Sent: Wednesday, June 28, 2006 11:25 AM
To: rv-list(at)matronics.com
Joel Haynes
Bozeman, MT
Tony Marshall
PostPosted: Thu Jun 29, 2006 7:26 am    Post subject: N557XW Flies Reply with quote
Congratulations Joel,
Great to have another flying RV in Montana.  If, when OSH time rolls around, you are ready to go, let me know.  It would be fun to have a small gaggle of RVs from the West parade out there together.
tony marshall
rv6
polson, mt
Tony Marshall
RV6
Polson, MT
joelhaynes
PostPosted: Thu Jun 29, 2006 10:06 am    Post subject: N557XW Flies Reply with quote
...much safer for everyone?
Not sure what you are implying but I have a complete flight test program mapped out that will be conducted in a SAFE manner.  I have time to complete it before Oshkosh and will do so if no major surprises are encountered.
Joel Haynes
RV-7A 0.5 hours
hansconser(at)gmail.com
PostPosted: Thu Jun 29, 2006 1:53 pm    Post subject: N557XW Flies Reply with quote
Congratulations Joel, sorry I couldn't be there. I am available to
help with oil cooler changes or any other help you may want.
Hans
Joel Haynes
Bozeman, MT
