Radio Tx poorly on ground, but good in the air
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aerobatic-List
gi(at)av8r.de
PostPosted: Mon Nov 03, 2014 4:37 am    Post subject: Radio Tx poorly on ground, but good in the air Reply with quote
David,
is the antenna grounded at the base (contact to the fuselage / metal on metal). It sounds to me like a grounding problem... Maybe there is corrosion around the base of the antenna.
Georg
Am 03.11.2014 um 13:01 schrieb DaveG601XL <david.m.gallagher(at)ge.com>:
I have a gremlin that I don't know how to troubleshoot. I have a 601XL all-metal airplane with an Icom A-200 radio, a RAMI com antenna mounted on the top skin and connected with RG-400 cable. I did all the installation myself. I have had this flying for 6 years now. It transmits just fine in the air. When I initially installed it, I would get comments that it was a bit garbled while transmitting on the ground. But it was always good enough to be able to operate out of tower controlled airports from time to time. Receiving wise, I hear just fine whether on the ground or in the air.
Just this summer, I started to get comments from fellow pilots that I was totally unreadable while transmitting on the ground. It would become crystal clear as soon as I took off. Does anyone have any thoughts of why this could be occurring or any place in particular I should start my troubleshooting??
David Gallagher
Zodiac 601 XL-B: flying, 280+ hours now
Next project under construction: Finish my father's Aircamper
http://forums.matronics.com/viewtopic.php?p=432801#432801
- The Matronics Aerobatic-List Email Forum -
http://www.matronics.com/Navigator?Aerobatic-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aerobatic-List All times are GMT - 8 Hours
