Posted: Mon Nov 03, 2014 5:34 pm Post subject: Radio Transmits Poorly Only When On The Ground |
At 06:06 2014-11-03, you wrote:
<david.m.gallagher(at)ge.com>
I have a gremlin that I don't know how to troubleshoot. I have a
601XL all-metal airplane with an Icom A-200 radio, a RAMI com
antenna mounted on the top skin and connected with RG-400 cable. I
did all the installation myself. I have had this flying for 6 years
now. It transmits just fine in the air, but when I initially
installed it, I would get comments that it was a bit garbled while
transmitting on the ground. It was always good enough though, as I
could still carry on a 2-way conversation, plus I was able to
operate out of tower controlled airports and not get any negative
radio comments. Receiving wise, I have always been able to hear just
fine whether on the ground or in the air.
Just this summer, I started to get comments from fellow pilots that
I was totally unreadable while transmitting on the ground. It would
become crystal clear as soon as I took off. Does anyone have any
thoughts of why this could be occurring or any place in particular I
should start my troubleshooting??
What tests have you run? Have you tried a different
microphone? Does your system include an intercom
or does the mic connect directly to the radio?
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Tue Nov 11, 2014 11:35 am Post subject: Re: Radio Transmits Poorly Only When On The Ground |
Bob,
I finally got back out to the airport with an assistant and my hand-held radio.
My all-metal airplane has an Icom A-200 radio going through a PS Engineering PM501 intercom, but I also have aux headset jacks that go directly to the Icom.
I transmitted both engine-off and engine-on. We set up a sequence where I used both my Bose X headset and a cheap passive headset. I swapped them between the pilot and co-pilot intercom jacks as well as the aux radio jack. I also varied the engine RPM to see if low voltage was an issue as I have a Jabiru with a dynamo alternator that does not charge at idle. We could not reproduce garbled transmissions with any combination. We did note that the anything transmitting out of the pilot intercom jacks had a slight more static that the other jacks.
The next time I go flying with some friends and their aircraft, I will repeat the test again with them listening in on airplane radios.
_________________ David Gallagher
Cincinnati, OH area |
