tonyrenshaw268(at)gmail.c Guest
Posted: Tue Nov 04, 2014 11:45 am Post subject: Resin Systems |
Giddy,
I have been using West Systems for non structural areas of late, and had the opportunity to speak to a Long Eze expert at Chino, LA. He told me that he wouldn't use West Systems for structure, and I recall that is reflected in the ACS manual. Other than SP Systems which is not available in Australia, to,clarify the original,SP20 is superseded and even though it has a picture of a Europa on their literature, it isn't approved (go figure), I would like a reminder on other approved Epoxies please.,this fellow swore by EZ Epoxy. Any advice much appreciated. The West Systems has a greater viscosity, a shorter pot life, and doesn't wet out as much.
Tony Renshaw
Lost Aussie.
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Tue Nov 04, 2014 12:47 pm Post subject: Resin Systems |
Hi Tony
That was quick let me know if you want any other dimensions.
The Europa build in England is only approved using SP Gurit Ampreg 21 which
replaced Ampreg 20 in 2010.
According to an Ampreg 21 leaflet I have on file, they have an office
supplier at Unit 1A/81 Bassett Street, Mona Vale, 2103 NSW,Australia.
Tel+61 [0] 2 9979 7248 Email sales-au(at)gurit.com
I would be very sure before using anything other than an approved system.
By the way Ampreg 21 is horrible stuff nowhere near as easy to use as 20,
but was introduced to satisfy Health & Safety !
Richard
peterz(at)zutrasoft.com Guest
Posted: Tue Nov 04, 2014 1:01 pm Post subject: Resin Systems |
Here in Canada/USA we use aeropoxy as supplied by the Europa dealer at the time.
Fwiw,
Pete a239
[quote] On Nov 4, 2014, at 3:46 PM, "Richard Collings" <rcollings(at)talktalk.net> wrote:
Hi Tony
The Europa build in England is only approved using SP Gurit Ampreg 21 which replaced Ampreg 20 in 2010.
According to an Ampreg 21 leaflet I have on file, they have an office supplier at Unit 1A/81 Bassett Street, Mona Vale, 2103 NSW,Australia. Tel+61 [0] 2 9979 7248 Email sales-au(at)gurit.com
By the way Ampreg 21 is horrible stuff nowhere near as easy to use as 20, but was introduced to satisfy Health & Safety !
Richard
rlborger(at)mac.com Guest
Posted: Tue Nov 04, 2014 1:48 pm Post subject: Resin Systems |
Tony,
Here in N.America we use Aeropoxy:
http://www.aircraftspruce.com/catalog/cmpages/aeropoxy.php
This is what was approved for us and is supplied with the kit by the N.America distributor.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Nov 4, 2014, at 1:44 PM, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Giddy,
Tony Renshaw
Lost Aussie.
Posted: Wed Nov 05, 2014 4:05 pm Post subject: Resin Systems |
Hi Craig,
Thanks for the detailed reply. I built my classic foam filled winged Europa with Ampreg 20, and I am sure it is a toxic product. I got flu symptoms and often a headache after using it. The West Systems 105 I too have been using on smaller jobs, and I find it a far healthier product to use. I have no effects, and only hope I did myself no harm with the Ampreg 20. It has been that long ago I used it that I hardly remember, but I do recall wearing my respirator for all the big layups. I dont mind the West Systems with the exception I believe it doesnt wet out as well, also I believe it may not be as strong in shear, easier to pry off a substrate (unzip as I call it). Still, the forces should normally not be shear forces that "peel" a layup off a substrate, so the effective strength is surface area based, not point load based with a perpendicular load pulling th le layup up and away from the job. I just got the wind put up me when the Long Eze expert said he would not use it as a structural resin. I interpret that as a system that entraps "loaded fibes" in a matrix, and as my smaller layups, like the door reinforcement ones, U believe the West should still be ok. I am though going to look into Aeropoxy and any other the list recommends. Problem is as you know,
In Aussie it is hard to get certain reains systems, and in the old days I would get Ampreg 20 with half its shelf life remaining, straight from the manufacturer/agent. Thanks for the input.
Tony Renshaw
[quote] On 5 Nov 2014, at 22:08, craig <craigb(at)onthenet.com.au> wrote:
Tony, I believe most of the other builders switched to west 105 system, we
have the West systems importer on the goldcoast here and I have spoken to
them a few times, the spec sheets they gave me for 105 indicated that it had
a higher rating
Than the ampreg epoxy system, yes it does have a shorter pot life, but I
didn't find that a problem. I just mixed smaller batches and was a lot more
practiced with my glassing work when I ran out of the ampreg, one thing, I
always had problems with the ampreg causing A LOT of swelling on any skin I
got it on a few hours after the event, I have never had that happen with the
west epoxy, mind you I did get virtually all the glass work done with the
ampreg, I have used the west system for
"mods" and the filling/sanding stage, west also had some other systems
equivalent to the araldite 420, but it was VERY thick
The factory told me, so would not be suitable for a lot of the stuff the 420
is called for
craig
