		Alfred Buess
				 Posted: Tue Nov 11, 2014 10:18 am    Post subject: AW: classic tail wheel |
				Frank,
 Where are you located? I have a spare stern post if you need to redo the
 whole spring installation.
 Regards, Alfred
 Alfred Buess
 CH-3700 Spiez, Switzerland
 Europa XS HB-YKI, Ercoupe 415-E N94804
 -----Ursprüngliche Nachricht-----
 Von: owner-europa-list-server(at)matronics.com
 [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von spcialeffects
 Gesendet: Dienstag, 11. November 2014 18:49
 An: europa-list(at)matronics.com
 Betreff: classic tail wheel
  --> <spcialeffects(at)aol.com>
 Hello all. I am building a classic mono and am fitting the tail wheel at the
 moment. I am also using the XS stern post instead of the classic build
 option. Today i drilled the hole in the stern post, in the correct location
 BUT i followed the wrong line. I drilled it in line with the angle of the
 spring mount of the wheel and not the fuselage bottom    . I have the
 correct distance from the bottom of the fuselage and the spring end 235mm,
 plus i have a good fit around the spring arm through the stern post but i
 now need 12 plys or shims under where the bolt goes.
       SO what im asking is should i go with the 12 shims and use a longer
 bolt OR file the hole at the bottom and and get the correct 5 or so shims
 but have an untidy fit around the stern post area? All views/advice welcome.
 Thanks Frank
 http://forums.matronics.com/viewtopic.php?p=433387#433387
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		spcialeffects
				 Posted: Tue Nov 11, 2014 11:30 am    Post subject: Re: AW: classic tail wheel |
				Thanks Alfred but thats a bit drastic to start again. All can be corrected its just which is the best way forward
