		mikeandlaurie3(at)netzero Guest
				 Posted: Thu Jun 29, 2006 7:23 pm    Post subject: fuel sender |
				Hi from Arizona.
 I went to test my 601XL fuel tank for leaks and the sender unit. With fuel in the tank, I am getting no ohms from the sender unit. Empty the tank and I get ohms! Is this because tank isn't grounded? (it isn't in the wing yet) Any thoughts out there? Thanks in advance.
 Mike
 N445ML
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Thu Jun 29, 2006 8:28 pm    Post subject: fuel sender |
				The sender and fuel tank must share ground with the gauge.  If there
 is no ground for the fuel tank then there is an incomplete circuit.
 Paul
 XL fuselage.
 At 08:20 PM 6/29/2006, you wrote:
  	  | Quote: | 	 		  Hi from Arizona.
 Mike
 N445ML
 Paul Mulwitz
 32013 NE Dial Road
 Camas, WA 98607
		bryanmmartin
				 Posted: Fri Jun 30, 2006 1:43 am    Post subject: fuel sender |
				If I recall correctly, that's the way it's supposed to work. The
 sender varies from abut 180 Ohms for an empty tank to about 10 Ohms
 when full. The gauge reads full scale for full: full scale meter
 reading = maximum circuit current = lowest resistance.
  Mike
  N445ML
 Bryan Martin
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
		taffy0687(at)yahoo.com Guest
				 Posted: Fri Jun 30, 2006 6:41 am    Post subject: fuel sender |
				Mike-- if you have already put FUEL in the tanks for leak ck, how do you plan on repairing any leaks ????
   Fritz
   Mike
   N445ML
   Get on board. [url=http://us.rd.yahoo.com/evt=40791/*http://advision.webevents.yahoo.com/handraisers]You're invited[/url] to try the new Yahoo! Mail Beta.
