saafbusiness(at)gmail.com Guest
Posted: Wed Nov 19, 2014 2:25 pm Post subject: Pulsar-List Digest: 3 Msgs - 11/18/14 |
Thanks Myron
I do have an intercom and yes I am using aircraft power to power the handheld radio
Are you saying to use the battery inside the radio or run the power directly to the aircraft battery ?
If will try both but using the internal radio battery requires charging it constantly of course which is a pain
I will try your other suggestions....as I figured, it is a trail and error of chasing like most electrical issues:)
On Wed, Nov 19, 2014 at 2:59 AM, Pulsar-List Digest Server <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2014-11-18&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2014-11-18&Archive=Pulsar
Pulsar-List Digest Archive
Total Messages Posted Tue 11/18/14: 3
Today's Message Index:
1. 01:03 AM - Re: Earth X lithium battery in 582 pulsar (Herbert Schmaderer)
2. 02:08 PM - Radio Engine Noise (Mark Fox)
3. 02:53 PM - Re: Radio Engine Noise (myrontruex)
________________________________ Message 1 _____________________________________
Time: 01:03:53 AM PST US
From: Herbert Schmaderer <herbert.schmaderer(at)aon.at (herbert.schmaderer(at)aon.at)>
Subject: Re: Earth X lithium battery in 582 pulsar
I am useing the Ballistic Performance Components model EV02 on my 912S
since 18 month. Charging voltage is determined by the regulator device =
13,6V. Very good start characteristic in winter time, once you get used
to the specifics of a Lithium battery.
Herbert
OE-CHS
Am 17.11.2014 20:27, schrieb Everett Collier:
> Is anyone else using a lithium battery in their Pulsar?
> I put an Earth X lithium battery in my 582 powered Pulsar. Much
> lighter than the old battery. I only have one flight on it, and am
> doing my annual now, so will be a few days before i fly again. What I
> am wondering about is that during the flight, I checked the battery
> voltage and it was only showing 12.8 to 12.9 volts. I think i was
> seeing 13.3 before. not sure what is going on and was wondering if
> anyone else is using one.
> Everett Collier
> N167EC
________________________________ Message 2 _____________________________________
Time: 02:08:11 PM PST US
Subject: Radio Engine Noise
From: Mark Fox <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)>
I have had my Pulsar for a long time...18 years....always has some engine
noise on transmission
But is seems to be much worse on transmission....engine noise
I am using a handheld Icom radios attached to the dash and always had good
luck
I think I have an Icon IC-A23 now
Anyone had good luck with noise filters ?
[image: Mark L. Fox Vice President [url=tel:321-626-4786]321-626-4786[/url]]
<http://myesig.com/esig/link-174057.php>
<http://myesig.com/esig/link-174063.php>
<http://myesig.com/esig/link-174061.php>
<http://myesig.com/esig/link-174062.php>
myesig.com <http://www.myesig.com/r.php?rc=CEA8A3>
________________________________ Message 3 _____________________________________
Time: 02:53:53 PM PST US
From: "myrontruex" <MyronTruex(at)comcast.net (MyronTruex(at)comcast.net)>
Subject: Re: Radio Engine Noise
Mark, are you using power from the airplane or the battery on the radio?
If you are connected to the aircraft power try unplugging it and running
it straight from the battery. If you have an intercom installed and it
is powered by the aircraft you could have the noise entering there. My
turn and bank indicator was producing a lot of hash until I did some
filtering inside it.
Your best source for clean power is to run a cable to the battery where
it can do its job. Yes a filter can help but it can be difficult to find
just where the noise is being injected into the system. If you have an
intercom and a pigtail on your radio you may be able to bypass the
intercom for a test. Loose screws on the headset plug wires can allow
electrical noise to enter the system too. Clean and tighten all the
connections.
Myron
Sent: Tuesday, November 18, 2014 5:07 PM
engine noise on transmission
good luck
myesig.com
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
ar-List" target="_blank">http://www.matronics.com/Navigator?Pulsar-List
myesig.com
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
MyronTruex(at)comcast.net Guest
Posted: Thu Nov 20, 2014 4:37 pm Post subject: Pulsar-List Digest: 3 Msgs - 11/18/14 |
Mark, just test the radio with the battery alone. Trying to find the source of the noise. If that does not improve it then try to bypass the intercom if possible by connecting directly to the radio interface cable.
Loose wires in headset plugs can create havoc. Ferrite beads rarely provide much help.
Sent: Wednesday, November 19, 2014 8:42 AM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: Pulsar-List Digest: 3 Msgs - 11/18/14
Thanks Myron
| Quote: | *
HTML Version:
Text Version:
Herbert
OE-CHS
| Quote: | Is anyone else using a lithium battery in their Pulsar?
Everett Collier
N167EC
luck
connections.
Myron
Subject: Pulsar-List: Radio Engine Noise
good luck
myesig.com
br> fts!)
myesig.com
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.mrrace.com">www.mrrace.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
