dhkey(at)msn.com Guest
Posted: Thu Jul 06, 2006 4:15 am Post subject: Rotax 912 fuel filter and gasolator |
912 installation manual calls for a fuel fliter with a mesh size .1 mm
between the tank and the fuel pump. Where did you find the fuel fliter with
the .1 mm mesh size?
I'd like to know your thoughts on gasolators and the brands you use. I can
not put one in the lowest point of the fuel system, it seems to me that one
anywhere would trap water as long as it runs through it. Is there something
I don't understand.
David
Posted: Thu Jul 06, 2006 5:33 am Post subject: Rotax 912 fuel filter and gasolator |
| I can
that one
something
| I don't understand.
| Thanks,
| David
David K/Gang:
Water is heavier than gasoline. If you pull fuel off the top of the
tank, water remains in the tank. Pull it out of the bottom of the
tank and it will then go through the gascolator, which can be drained
periodically.
I have a homemade gascolator. Fuel tank outlet is in the lowest part
of my fuel tank. Everything comes out of that hole. Even the last
drop of fuel. From the outlet I loop the fuel line under the tailboom
and back to the Facet Fuel Pump. At the lowest point of the loop, I
installed a "T". From the "T", I run a line forward to the lowest
point in my fuselage, which is between the gear legs. I have a Briggs
and Stratton nylon valve at the end of the line just prior to a 90 deg
fitting and short piece of fuel line to exit the bottom of the
fuselage. It is right next to the vent line from the top of the tank
that vents out the bottom of the fuselage. Water and contaminants
collect in the fuel line that lays in the keel of the airplane.
I have been using a Purolator Fuel Filter, same one, since 1984 on my
Ultrastar. Uses nylon mesh filters.
This is the filter:
http://www.midwayautosupply.com/searchby.asp?txtSearch=Purolator&select1=mfg
I did replace the glass cylinder with a piece of aluminum tubing of
the same size. First night it was on the Ultrastar the glass cylinder
cracked and I lost six gals of gas. I may have overtightened it, or
it may have been a defective glass part. However, was not going to
take another chance of it cracking. I believe John W flies with the
same filter, glass cylinder and all.
_________________ John Hauck
Titus, Alabama |
Dennis.Kirby(at)kirtland. Guest
Posted: Fri Jul 07, 2006 7:50 am Post subject: Rotax 912 fuel filter and gasolator |
<< I'd like to know your thoughts on gasolators and the brands you use.
Thanks, David >>
David, and Kolbers -
As John H does, I also use a home made gascolator. I made it from a 3 inch
long piece of 1.5" diam PVC, with end caps (2) glued on. (This was an idea
I got from someone else on this List.) It has three fittings: an incoming
fuel nipple, an outgoing fuel nipple (near the top end), and Curtis type
drain valve on the bottom. Each of these three fittings is threaded into
the PVC gascolator, and sealed a with fuel-proof Permatex goop. I installed
it at the lowest point in the fuel system, and the drain pokes out the
bottom just aft of the gear legs. Any water that gets sucked thru the fuel
lines from the tank will collect there, and can be easily drained.
I also use the glass Purolator fuel filter, with the nylon mesh screen. I
just changed the screen for the first time (at 50 hrs) a few months ago.
Although it looked fairly clean when I changed it, the mesh was actually
full of lint that is not apparent to the eye. It was nearly clogged. 50
hours is a good target number for changing the fuel filter screen.
Dennis Kirby
Mark-III, 912, in
Cedar Crest, NM
