FLYaDIVE(at)aol.com Guest
Posted: Fri Jun 30, 2006 12:41 am Post subject: Alternator Field Switch |
In a message dated 6/29/06 7:23:43 PM Eastern Daylight Time,
endspeed(at)yahoo.com writes:
| Quote: | Is there a reason to have a field switch?
Bob Sultzbach
Bob:
There are two reasons for a Field Switch:
1 - To isolate the alternator from the electrical system.
This is helpful in diagnosing a problem and when the ACU goes off line and
you want it to cool and reset.
2 - In case of an electrical fire.
There are also some not as relevant reasons:
Voltage spikes when starting
Reducing load on the starting of the engine
Control of the alternator or alternators
Barry
"Chop'd Liver"
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Fri Jun 30, 2006 2:12 am Post subject: Alternator Field Switch |
On Jun 30, 2006, at 4:38 AM, FLYaDIVE(at)aol.com (FLYaDIVE(at)aol.com) wrote:
| Quote: | There are also some not as relevant reasons:
I don't really want to pick a fight but these wives' tales seem to persist: voltage "spikes" and engine load when starting. I have certainly seen low voltage caused by starter load but I just don't know where voltage "spikes" would come from. Likewise, the load from the alternator on an engine turning at 150-200 RPM during cranking is inconsequential as the alternator is not turning fast enough to produce an output above battery voltage so it is delivering no current and hence placing no load on the engine. The only load the alternator places are frictional loads, and those exist whether the field is active or not, and the slightly extra battery drain of 2 or 3 amps to excite the field.
Brian Lloyd 361 Catterline Waybrian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
willslau(at)alumni.rice.e Guest
Posted: Fri Jun 30, 2006 3:07 pm Post subject: Alternator Field Switch |
On that note, just got my new Sport Aviation magazine, and the technical counselor article is all about needing an avionics master switch to protect your electronics from spikes caused by "inductive kicks". That'll probably be enough to keep these OWTs going stronger than ever. Argh.
William Slaughter
