jhasbrouck(at)woh.rr.com Guest
Posted: Sun Jul 02, 2006 8:52 am Post subject: F1070 roll construction angles |
For those with slo-build fuse: What angle stock did you use to make the
roll construction angles ( 1070A & B ) used to roll the side skins? These
are only used for rolling the skins I think so would some angle from the
aviation dept of Lowes suffice? Looks like 3/4 X 3/4 angle, maybe .125
thickness but I can't find the answer in the plans. Any help greatly
appreciated.........thanks....john
John Hasbrouck #40264
soon to be rolling side skins
jim(at)CombsFive.Com Guest
Posted: Sun Jul 02, 2006 9:17 am Post subject: F1070 roll construction angles |
3/4 x 3/4 and for sure .125 thickness. And you will need lots of clamps.
Anything less will not work - Been there and tried that, it was not pretty.
Jim Combs
N312F
40192
rvbuilder(at)sausen.net Guest
Posted: Sun Jul 02, 2006 9:32 am Post subject: F1070 roll construction angles |
John,
I used some angle that was in the kit. IIRC I didn't have any other
angle shortage, and I'm almost done with the fuselage, so it must have
been for that purpose. You can see here for more info:
<http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&c
ategory=613&log=11206&row=76>
Michael Sausen
-10 #352 Fuselage
Rick S.
Posted: Sun Jul 02, 2006 12:16 pm Post subject: F1070 roll construction angles |
John,
Use the 3/4 x 3/4 x 1/8" angle stock.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
