by0ung(at)brigham.net Guest
Posted: Sun Jan 15, 2006 5:11 pm Post subject: mode c vail |
Hi,
Your not allowed inside the mode-c circle without a transponder and alt. encoder.
Roger Lee
Tucson, Az.
xxxxxxxxxxxx
if you call an hour or more in advance you can get permission to go through........ every year I go to MV I have to call to get permission....... also if you have no electrical system you can get a permanent waver......
but when I have traveled through I am reminded to get the equipment installed and working..... but when I call and talk to the supervisor he tells me that on a once a year trespass through the area is not a problem.... but if I were to make a habit of it I would be required to have it working.
boyd
Roger Lee
Posted: Sun Jan 15, 2006 6:57 pm Post subject: Re: mode c vail |
Hi John,
Thanks for the update. I did not know an ultrlight could get permission to go through class B airspace.
Some of the others are debating about an electrical system. Doesn't a lighting coil and a battery make up an electrical system? Needs better defining I believe.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
