Alternator failure. Info provided
Goto page 1, 2, 3  Next
mstewart(at)iss.net
PostPosted: Wed Jun 28, 2006 3:47 am    Post subject: Alternator failure. Info provided Reply with quote
After 250 hours my 14684 ND alternator finally gave way. Of course I was a thousand miles from home when it did. Went running around the big city of Denver for hours getting a replacement. Best I could come up with was a 14870 for a 1988 Chevy Sprint. Most auto part shops did not even show the 14684 number. Although the mount ears on the 14870 were in a different location, as was the bat post, I was able to finagle washers and new bolts to get her back up and flying for the ride home.
The 14684 alternator I bought from Vans for my RV-8 behaves differently than the new 14870 Im now running. The 14684, once the field was excited, would keep charging as long as the pulley was turning. You could turn off the field and it would keep charging. The new 14870 will shut off when the field is off. I have the OV protection on a contactor. Also sometime during the alternator failure, my Lightspeed ignition blew its 3 amp fuse. Klaus said I should have a 5 amp in there anyway.
I took the 14684 to an alternator shop for repair when I got home and he said it looked like the stator was cooked, but he could not get any parts for it. So its now a door stop.
Information for the group if you happen to be on the road and cant find the 14684 locally. You can get the 14870 to work on your RV and a lyco mount with new bolts and washers to shim for alignment.
Best
Mike Stewart
mstewart(at)iss.net
PostPosted: Wed Jun 28, 2006 6:45 am    Post subject: Alternator failure. Info provided Reply with quote
Yes the new alternator 14870 is a 55amp alternator. So was the old one.
It’s a ND bought from Autozone in stock, lifetime warrantee whos receipt is now permanently in the plane.
The ears were oriented correctly, it was the ear spacing that was off. I run at 12 amps normally.
Damn all these alternator problems anyway. In 1800 hours of RV flying in 2 planes, this is my 5th alternator. ARGH!
A friend recommended I put the 4” pulley on. Im very tight in the cowl with my 6cyl installation. Not sure if I could get it in there.
Mike
From: Charlie Kuss [mailto:chaztuna(at)adelphia.net]
Sent: Wednesday, June 28, 2006 9:46 AM
To: Stewart, Michael (ISS Atlanta)
Subject: Re: AeroElectric-List: Alternator failure. Info provided
Mike
 Thanks for the report. Could you tell me what brand or what auto parts store you found your alternator at? Are these the 35 amp or 60 amp models? FYI, you can easily "clock" the two case housing halves to get the ears oriented like your original alternator. Many of the various alternator part numbers differ only in how the case halve are oriented to each other, as required by the auto manufacturer's requirements.
 I'm a firm believer in using parts which are automotive based and readily available. Your 4 hour ordeal is proof of the wisdom of this. I like the starter shown below. It's off of a Toyota pick up truck. See
http://cgi.ebay.com/ebaymotors/Airboat-Starter-forTextron-Lycoming-Engines-149tfw-NR_W0QQcmdZViewItemQQcategoryZ26439QQihZ002QQitemZ4580254772QQtcZphoto
FYI  for maximum alternator life, your nominal current draw from the alternator shouldn't exceed 60% of it's rated output. Forcing a 35 amp unit to produce 25 amps for long periods is a sure route to short life. The rectifier diodes are heat sensitive. These items are the weak link in most alternators. Cheapo rebuilds use cheapo diodes. Real ND, NAPA or other name brand diodes go a long way to ensuring long life.
Charlie Kuss
Best
Mike Stewart
frank.hinde(at)hp.com
PostPosted: Wed Jun 28, 2006 7:40 am    Post subject: Alternator failure. Info provided Reply with quote
Uh-oh...I have an Autozone 60A (Toyota Camry) alt on my 7a (not flying yet)...Hope I did'nr make a bad decision here.
BTW...Autozone have your name in their computer so they can find you by your phone number if you show up with a dead part a long ways from home.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stewart, Michael (ISS Atlanta)
Sent: Wednesday, June 28, 2006 7:42 AM
Subject: RE: Alternator failure. Info provided
Mike
Subject: Re: Alternator failure. Info provided
Mike
Charlie Kuss
Best
Mike Stewart
nuckollsr(at)cox.net
PostPosted: Wed Jun 28, 2006 7:50 am    Post subject: Alternator failure. Info provided Reply with quote
It s a ND bought from Autozone in stock, lifetime warrantee whos receipt
A friend recommended I put the 4 pulley on. Im very tight in the cowl with
Why the 4" pulley? Running an alternator "fast" bears
on mechanical wear rate issues. Aside from B&C's
conclusion that "fast" alternators were at-risk
for vibration induced bearing failures (for which
they elected to carefully balance new alternators)
there are no issues I'm aware of that warrant
slowing the alternator down with a larger pulley.
Alternator speed does not bear on electrical failures
unless they are aggravated by heating where turning
faster moves more air.
Mark Phillips in TN
PostPosted: Wed Jun 28, 2006 7:55 am    Post subject: Alternator failure. Info provided Reply with quote
In a message dated 6/28/06 9:54:14 AM Central Daylight Time, mstewart(at)iss.net writes:
MIke- any B&Cs in this gang of five?
Mark do not archive
From The PossumWorks...
mstewart(at)iss.net
PostPosted: Wed Jun 28, 2006 9:14 am    Post subject: Alternator failure. Info provided Reply with quote
No.
First 3 were the old vans 35 amp alt. . 79 Honda Civic was the application as I recall.
Next 2 were the 14684 ND ones.
Mike
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com
Sent: Wednesday, June 28, 2006 11:53 AM
Mark do not archive
ainut(at)hiwaay.net
PostPosted: Wed Jun 28, 2006 10:16 am    Post subject: Alternator failure. Info provided Reply with quote
Over the years, I've have terrible luck with Autozone electrical items,
alternators, starters, and etc. I won't put them on my cars now.
Autozone does make good on the warranty but I hate having to replace
things multiple times. On a plane, the risk is high. Get one from a
reputable jobber. Cost is about the same.
David M.
Frank
brinker(at)cox-internet.c
PostPosted: Wed Jun 28, 2006 11:05 am    Post subject: Alternator failure. Info provided Reply with quote
AMEN
Dick Sipp
PostPosted: Wed Jun 28, 2006 7:25 pm    Post subject: Alternator failure. Info provided Reply with quote
Mike:
Have a look at the new Plane Power alternators. http://www.plane-power.com/
I have one for the 10, nice piece of work and dirt simply to wire as well as a bolt on for the 540. Integrated regulator and overvoltage protection.
Frogman
brian
PostPosted: Wed Jun 28, 2006 7:28 pm    Post subject: Alternator failure. Info provided Reply with quote
On Jun 28, 2006, at 1:06 PM, Stewart, Michael (ISS Atlanta) wrote:
No.
So, in terms of time and trouble, do you think that maybe the B&C alternator and controller would be cheaper in the long run?
Brian Lloyd                         361 Catterline Waybrian-yak AT lloyd DOT com          Folsom, CA 95630
+1.916.367.2131 (voice)             +1.270.912.0788 (fax)
— Antoine de Saint-Exupéry
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
mstewart(at)iss.net
PostPosted: Thu Jun 29, 2006 3:01 am    Post subject: Alternator failure. Info provided Reply with quote
Hmm. Good ?
I would say its about a wash at this point. Since Im measuring against 2 planes and since I do not know what the failure rates are on the B&C.
Lets suppose this. Lets suppose I only care about the money, which practically speaking I do.
Lets say the the B&C should last as long as an automotive device should. If I were to assume the average car today made it 100,000 miles on an alternator (which I think is low ball since I have 2 cars with combined 300,000 miles with no alternator change). And I assume average 36mph(that’s what my car says I average). That’s 2777 hours of operation before failure. My MTBF of the 4 replacements has been 500 hours. That means I would be by buying 5.5 units to make 2777 hours of operation. (at)$118 per unit that’s $650 worth of alternators to make the 2777 hours.
I really need the failure rate of the B&C now to make a comparison.
Mike
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian Lloyd
Sent: Wednesday, June 28, 2006 11:26 PM
No.
Hopperdhh(at)aol.com
PostPosted: Thu Jun 29, 2006 4:39 am    Post subject: Alternator failure. Info provided Reply with quote
I know that it is really a bummer to have alternator problems.  Almost all of these problems are due to excessive temperature.
Even a 35 amp alternator would last a lot longer (probably at least a 1000 hours) if it had a decent cooling fan.  Even one turning the wrong direction would be a lot better than none at all.  Alternators are only about 50 percent efficient so there is a lot of heat to get rid of.  If you're going to count on only the blast tube, make a good shroud for the back of the alternator.
There is a lot of this information in the archives, so do not archive.
Dan Hopper
Walton, IN
RV-7A
brian
PostPosted: Thu Jun 29, 2006 4:54 am    Post subject: Alternator failure. Info provided Reply with quote
On Jun 29, 2006, at 6:54 AM, Stewart, Michael (ISS Atlanta) wrote:
Hmm. Good ?
If Bill Bainbridge of B&C is to be believed, the failure rate of B&C alternators is very close to zero. When I first talked to him 7-8 years ago he claimed that the only failures had been the result of misinstallation and not from outright mechanical or electrical failure. I am sure there have been some failures but barring the customer doing something wrong with it, there have been precious few.
(And before I really stick my foot in my mouth I have to state again that my conversation with Bill on this is many years old and could very well be wrong. OTOH, I have never heard anyone complain about B&C alternators failing, only that they cost a lot of money.)
So you are at a wash on cost for the alternator but what about time and any costs incurred by being caught out somewhere else while fixing it, e.g. hotel room, taxi or car rental, restaurant, etc.? It is amazing how much the total cost of even a simple failure while on the road can add up.
There are pretty much three options for the CJ6A: the stock Russian or Chinese generator, a Delco truck alternator with a modifed shaft and adaptor plate, or a B&C alternator. I am going to go with a B&C alternator. I prefer flying to fixing and anything I can do to make the airplane more reliable is what I am going to do.
Brian Lloyd
FLYaDIVE(at)aol.com
PostPosted: Fri Jun 30, 2006 12:09 am    Post subject: Alternator failure. Info provided Reply with quote
In a message dated 6/29/06 7:08:40 AM Eastern Daylight Time, mstewart(at)iss.net
writes:
Mike
Mike:
No, what you really need to do is stop being a bean counting manager and
become an engineer and look at the installation. The variable in the equation is
NOT the alternator but the installation. Alternators come off the assembly
line much faster, for more planes and with much tighter tolerances than the
planes do.
LQQK at what is failing and why. The problems I see and I have seen a lot,
way more than 2 planes; is the install.
Belts too tight
Belts too loose
Alignment of the alternator sheave to the ring gear out of whack
Wrong Belts being used - There is a difference in 'V' grove between aviation
and automotive.
Belts not seating properly in the sheave
Alternator not mounted secure - Too much vibration
Cracked alternator mounts
Cracked alternator tension brackets
Improper nuts & bolts used - Course thread Vs fine thread
Ridiculous stacking of washers in attempts to align alternator with ring gear
Bracket mounting bolts not torque correctly
No safety tabs on mounting bolts
No safety wire on tension bracket bolts
Safety wire installed incorrectly
OVER torquing of Field and B+ nuts
No securing method on alternator bells
Improper wire length and No service loop on alternator wires
POOR electrical grounds on the entire engine and plane
So, you can see, you have to LQQK at the entire picture and not micro manage
one device.
Barry
"Chop'd Liver"
QA/QA Manager
SPC
Q1
ISO 9001
Tech Sales Engineering
A&P
brian
PostPosted: Fri Jun 30, 2006 1:53 am    Post subject: Alternator failure. Info provided Reply with quote
On Jun 30, 2006, at 3:59 AM, FLYaDIVE(at)aol.com (FLYaDIVE(at)aol.com) wrote:
--> AeroElectric-List message posted by: FLYaDIVE(at)aol.com (FLYaDIVE(at)aol.com)
In a message dated 6/29/06 7:08:40 AM Eastern Daylight Time, mstewart(at)iss.net (mstewart(at)iss.net)
writes:
 Mike
Mike:
planes do.
Your points about installation are well taken and should be heeded by all those using automotive alternators.
OTOH, what Mike said was that the stator was fried. That is what happens to an alternator operated too close to its maximum current rating. Automotive alternators, unless they are "hot rated", cannot operate anywhere near their ratings without self-destructing. This is a failure mode that occurs all the time with boats where the alternator is called upon too recharge the deep-cycle battery bank. It also happens all the time in cars that have megawatt stereo systems that draw huge amounts of power from the electrical system.
How do I know about this? Well, I became really good friends with the guy who rebuilds alternators in the Virgin Islands as I was a member of the "stator of the month" club. He was very up front about not providing a warrantee on rebuilt automotive alternators to boats with big battery banks (me) or people with big stereos in their cars. In fact, I keep a couple of stators in my spares kit. (I got so I could change a stator in about an hour including removal and reinstallation of the alternator on the engine.) I learned to be careful to monitor current output and alternator temperature to minimize failure.
The solution is simple: if you are using an automotive alternator that is not explicitly designed to operate near its rated output (hot rated), make sure your average current consumption is below 50% of the rated output of the alternator. 50A alternator? Don't design your electrical system to require more than 25A under normal, continuous operation. Intermittent loads like landing lights (unless you leave them on all the time), gear retraction systems, comm radios while transmitting, etc., are not the problem as you only use them for short periods of time. Everything else that gets turned on and left on counts.
I know that Bob recommends keeping the load on the alternator below 80% of max rating but IMHO that is not conservative enough for most automotive alternators. (Maybe it is if you have really good cooling.)
The bottom line is that, regardless of proper installation, alternators can and will self destruct if operated at their rated output. Only those that are "hot rated", i.e. have their output specified at a higher operating temperature, usually something like 100C, will be able to deliver their max output under continuous load conditions.
Oh, and hot-rated alternators cost more.
Brian Lloyd
Dale Ensing
PostPosted: Fri Jun 30, 2006 3:56 am    Post subject: Alternator failure. Info provided Reply with quote
What are alternator bells?
Dale
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
FLYaDIVE(at)aol.com
PostPosted: Fri Jun 30, 2006 4:24 am    Post subject: Alternator failure. Info provided Reply with quote
In a message dated 6/30/06 5:57:51 AM Eastern Daylight Time,
brian-yak(at)lloyd.com writes:
Brian:
Someone is feeding you a bunch of bunk!
DON'T SPREAD THE BUNK!
Hot rated ... MADE UP NONSENSE!
The same companies that make automotive alternators make aircraft
alternators. For example:
1972 Ford Pickup with A/C (61 amp), as this is what the DOFF-xxxxx P/N
crosses to in the Ford books.
DOFF-10300J AL12-F60 <- FULL P/N
The ONLY difference is the NAME PLATE.
I have taken both plane and car alternators, disconnected the regulator and
ran them with a variable load and up to 5000 RPM. I was able to get 107 Amps
out of a 60 Amp Alternator. Sure it got hot, but it did not fail. ALL
alternators are under rated. They have to be if you expect them to work. Keeping
the LOAD at 80% of the source is just GOOD design practices. Just because a
wire can handle 15 Amps does not mean you run it at 15 Amps.
What is common between plane and boats is VIBRATION. How does a Stator fail?
From Vibration. The stator is basically a SOLID unit. It does not fail ...
The bearings and the bell fail Because of Vibration, which causes the stator
to go off center and usually destroying the brushes and field coil. I have
NEVER seen a stator fail that did not involve the bearings or bell.
As far as auto Vs plane alternators ... Give me a NEW auto type any day.
They keep up with technology.
Don't believe it? Look at the smaller size and higher output that we have
today. Other than big business using data such as MTBF to set up a warranty
program ... YES, they reduce the quality of the components to keep operational
times just a farts breath longer than the warranty period. THAT is why I do not
rebuild with OEM parts.
Barry
"Chop'd Liver"
FLYaDIVE(at)aol.com
PostPosted: Fri Jun 30, 2006 4:31 am    Post subject: Alternator failure. Info provided Reply with quote
In a message dated 6/30/06 8:00:48 AM Eastern Daylight Time,
densing(at)carolina.rr.com writes:
Dale
Dale:
Good question, you are the only one to ask.
Motors, alternators and even starters have bells. They are also called END
BELL. They are the front and rear housing that support the bearings. They got
their name from the old steel motors. When they are removed from the rest of
the housing and struck with a hammer they RING like a bell. Today aluminum
has replaced the steel end bells, both for lightness and heat transfer, as well
as production cost.
Barry
"Chop'd Liver"
PostPosted: Fri Jun 30, 2006 5:39 am    Post subject: Alternator failure. Info provided Reply with quote
Barry,
Your list of failure modes is certainly extensive and all are installation related, and I agree with each and every one.  However, I noticed that none of the failures that you have seen were caused by overheating.  Even if the installation is perfect in every respect and there is not enough cooling air brought to the alternator, it will certainly fail.  A fan is very desirable, if not essential.  It is possible that a properly installed blast tube could do the job, but keep in mind that it should provide as much airflow as the fan originally did.
I worked with alternators back in the sixties.  Actually I was on the design team that built the first regulators that were put inside the alternator.  The first application was the 1968 Pontiac Gran Prix (when the Gran Prix was the top of the line).  I learned then that alternators can run at 100 percent output for hours on end at underhood temperatures (125 degrees C or 257 degrees F ambient) -- with a fan.  The current output is higher at first when the stator winding is cool, and then drops off to the rated current as it heats up.  Increasing the voltage causes the current to go up due to increased field current.  At that time at least, alternators were rated conservatively and a 65 amp alternator (twice the output of a typical generator of the time) would self limit at 65 amps -- plus or minus a few percent depending on the exact temperature and voltage.  But it would never destroy itself.  Exceptions to this would be if the cooling air were blocked off or if the fan were not present.
Any copper wire will fry (burn up the insulation) if it gets too hot.  Blow some air on it and it will run cooler at the same current.  Almost any failure mode will be less at a lower temperature.
Dan Hopper
RV-7A
In a message dated 6/30/2006 4:13:36 A.M. Eastern Daylight Time, FLYaDIVE(at)aol.com writes:
Belts too tight
Belts too loose
and automotive.
one device.
Barry
"Chop'd Liver"
QA/QA Manager
SPC
Q1
ISO 9001
A&P
PostPosted: Fri Jun 30, 2006 6:07 am    Post subject: Alternator failure. Info provided Reply with quote
snipped
Brian:
snipped
operational
why I do not
Barry,
I work on auto electrical systems every day. I take exception with
your opinion that OEM parts are all junk. Some manufacturers have cut
back on parts quality. They are used in by only certain
manufacturers. They are the ones you hear being on the verge of
bankruptcy on the TV news.
Nippon Denso is not one of them. ND electrical parts are extremely
reliable, as are ND factory remanufactured. My experience is that the
re-mans sold by discount auto stores like Advance Auto Parts and Pep
Boys use much lower quality components in their remanufactured parts.
Sure, they offer life time warranties. What do they care? Their unit
costs are very low (thanks to using cheap parts and labor). In
addition, they aren't the ones doing the labor twice (or more).
As a professional auto mechanic, using poor quality parts is bad
business for me. I only get paid once. My customer wants the repair
done correctly the first time. If the repair fails, I get to fix it
again for free the second time. Add to that, customer ill will, and
it adds up to a losing proposition for me. Having an electrical
component fail away from home gets expensive for all of us, as
aircraft owners. Loss of time gets expensive, if you have to pay for
overnight shipping, or worse, a rental car and a motel room.
Buy B&C Specialties or purchase from an auto parts source. Just
make sure you get high quality parts. You can't go wrong with genuine ND parts.
Charlie Kuss
Page 1 of 3
