eskflyer(at)lvcisp.com Guest
Posted: Thu Jul 06, 2006 4:56 pm Post subject: kitfox 2 floats setup |
HELP . i just bought a set of North Aire floats .
htey were on a Raven . what incidence and where do i put the step in relation to the CG of aircraft any help would be great .
John Perry
kitfox 2 N718PD
eskflyer(at)lvcisp.com (eskflyer(at)lvcisp.com)
580-695-8778
noelloveys(at)yahoo.ca Guest
Posted: Thu Jul 06, 2006 7:06 pm Post subject: kitfox 2 floats setup |
John the step is not the most important part to locate. the centre of flotation is. The CG of the plane should be directly over the centre of flotation. Angle of incidence should be less than 5 deg mine is 1.45 deg.
Noel [quote]
