rveighta(at)earthlink.net Guest
Posted: Thu Jul 06, 2006 7:48 am Post subject: Gluing Canopy Skirt - RV-8 |
I'm leaning towards gluing my canopy to the frame using Sikaflex as
detailed in numerous posts on this list, but I'm not quite sure how to
approach the issue of gluing the skirt on.
It appears that Sikaflex would be ruled out due to the reqirement to
have a 3/16" bead between the skirt and canopy/ frame. Someone
in the archives mentioned using Scotch SemWeld. Any other suggestions,
and what were the results of the SemWeld?
Walt Shipley
mstewart(at)iss.net Guest
Posted: Thu Jul 06, 2006 8:36 am Post subject: Gluing Canopy Skirt - RV-8 |
I glued mine. There is no reason why you could not get a bead in there.
There is so little pressure on the canopy and skirt, the bead is of
little consequence anyway IMHO. 250hours at speeds other RV-8's only
dream about:)
Best,
Mike
fstringham
Posted: Thu Jul 06, 2006 10:47 am Post subject: Gluing Canopy Skirt - RV-8 |
Walt
Like you I contemplated and just about went with the Sika canopy option. The
more I read, the more I realized that there isn't alot of long term
historical info on this product used in this application. Decide i didn't
want to be trail blazer. I finally went with the tried and true Van's
method. It was alot easier than I thought and came out great.
Frank (at) sgu and slc.......wiring...plus..........
| Quote: | From: rveighta <rveighta(at)earthlink.net>
Reply-To: rv-list(at)matronics.com
To: "rv-list(at)matronics.com" <rv-list(at)matronics.com>
Subject: Gluing Canopy Skirt - RV-8
Date: Thu, 6 Jul 2006 11:46:36 -0400 (EDT)
Walt Shipley
rv8(at)lazy8.net Guest
Posted: Thu Jul 06, 2006 2:14 pm Post subject: Gluing Canopy Skirt - RV-8 |
Stewart, Michael (ISS Atlanta) wrote:
dream about:)
Best,
Mike
Well, Mike, I'm not sure WHO is dreaming...why don't you show for one of
the races and give us a demo?
John
aerobubba(at)earthlink.ne Guest
Posted: Fri Jul 07, 2006 5:21 am Post subject: Gluing Canopy Skirt - RV-8 |
Hi Walt-
As I understand it, the thick bead specified in the sikaflex instructions
is to account for differential thermal expansion of the plastic window and
metal window frame. The difference between the coefficient of thermal
expansion for plex and steel is huge. With fiberglass and plex the
difference is very much smaller, and should require a much thinner layer of
adhesive. I can't give you any hard numbers at the moment, as I've not
found real consistent numbers for the different coefficients yet, but I do
believe a fairly thin layer is in order. Perhaps this topis is right up
the alley of someone on this list?.
snip-It appears that Sikaflex would be ruled out due to the reqirement to
Walt Shipley
glen matejcek
aerobubba(at)earthlink.net
finn.lassen(at)verizon.ne Guest
Posted: Fri Jul 07, 2006 6:11 am Post subject: Gluing Canopy Skirt - RV-8 |
John, you do know he's got an IO-540 in his Super-8, don't you?
Finn
John Huft wrote:
> <mstewart(at)iss.net>
> dream about:)
> Best,
> Mike
> Do not archive
of the races and give us a demo?
John
amoulin(at)qc.aira.com Guest
Posted: Fri Jul 07, 2006 6:59 am Post subject: Gluing Canopy Skirt - RV-8 |
Hi,
Just for your information, I did a RV-3 canopy with Sikaflex and after about
3 weeks the canopy got unglued!
Antoine Moulin
Posted: Fri Jul 07, 2006 7:28 am Post subject: Gluing Canopy Skirt - RV-8 |
This is the first I have heard of any canopy glue failures using
Sikaflex.
Can you provide any info as to the installation? Were all the
manufacturers installation instructions followed? Scuffing, cleaner,
primer, bead?
Was the separation in flight or noticed on the ground?
Details would be very helpful for others.
Mike
Posted: Fri Jul 07, 2006 7:53 am Post subject: Gluing Canopy Skirt - RV-8 |
Yes, Finn, I know. It would seem that means he can blow more hot air.
I just can't help but be suspicious of these airplanes...Super-6,
Super-7, Super-8, Rockets, Harmon and F-1. Why is it they never show up
for a race like the AirVenture Cup? I think is because then they would
have to stop bragging about how fast they are. I think the truth is the
airplanes are so far out of balance with that 6-cylinder in front they
just burn more gas, and produce more hot air.
The gauntlet has been tossed.
John
Finn Lassen wrote:
Finn
>> dream about:)
>> Best,
>> Mike
>> Do not archive
> John
http://wiki.matronics.com
rv8ch
Posted: Fri Jul 07, 2006 7:59 am Post subject: Gluing Canopy Skirt - RV-8 |
Antoine Moulin wrote:
Hi,
about 3 weeks the canopy got unglued!
Antoine Moulin
Salut Antoine,
Which sikaflex product did you use?
Why do you think it didn't work for you?
How did you end up attaching the canopy?
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
T.gummo(at)verizon.net Guest
Posted: Fri Jul 07, 2006 9:41 am Post subject: Gluing Canopy Skirt - RV-8 |
I have a Harmon Rocket-II with an IO-540 J4A5 and a MT four blade prop. I
have never made the claim that my plane was faster. I am now 10 knots
slower because of the four bladed prop. With the 2 prop Hartzell, the plane
was faster. My engine is stock 250 HP. My tests which were done a long
time ago showed that I trued out at 180 Knots (no wind) at 10.5 gph in the
10500/11500 altitude range.. Now with the MT prop, I cruise at 170 Knots
True. (However, the four bladed prop does look great with my military paint
scheme.)
I am a first time builder and I built on a budget. There was no attempt to
maximize for speed as most Rockets have built up engines with more than 250
HP, so my plane would not have been able keep up anyway. I built to fly!
What I have found is that when I fly with other RVs, my fuel flows are
within a couple of tenths and my MP is lower.
Lets get to what is really important. I build my plane for me. It puts a
smile on my face every time I fly it. Harmon Rocket-II cockpit is bigger
than the RV-4 it is based on. It even has more room for the backseater.
The two people, who helped me the most build it, weigh in at 230 and 280. I
am also no light weight. The Harmon Rocket-II with the battery up front has
a very forward CG. I can however, fly with a person who weight 318 pounds
in the back seat and still be within limits.. There is NO RV-4 that I know
of that can do that. Most RV-4's and RV-8's have to be careful about flying
a large person in the rear seat. If I can close the canopy with you in the
backseat, you can fit inside the seatbelt, and you don't interfere with the
stick, etc, I can and mostly will give you a ride.
No I don't race but I have given over one hundred and thirty different
people rides in the 280+ hours in the last four years. You go ahead and
race, I will continue to share my love of flying with as many people as I
can. Different strokes for different folks.
While my plane isn't that fast, I will met you overhead APV (OK, in the next
valley to stay out of the traffic pattern). As we pass head-on, the fight
will be on. Your speed will only help you if you are running away.
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
http://mysite.verizon.net/t.gummo/index.html
Posted: Fri Jul 07, 2006 9:48 am Post subject: Gluing Canopy Skirt - RV-8 |
Bonjour Mickey,
I used Sikaflex 295, primer 209,cleaner 205, the plexiglass and the frame
was well sanded and thickness controled with popsicle wood sticks. I think
the trouble is the paint that I used on the frame.The fix was holes and pop
rivets. I am making the skirt rigth now so in few days I may have some
pictures available.
Antoine
Posted: Fri Jul 07, 2006 10:28 am Post subject: Gluing Canopy Skirt - RV-8 |
So it separated at the paint and not the glue?
That would make sense to me. I have no doubt the glue is tougher than
the paint its glued to.
Mike
rv8ch
Posted: Fri Jul 07, 2006 10:49 am Post subject: Gluing Canopy Skirt - RV-8 |
| Quote: | I used Sikaflex 295, primer 209,cleaner 205, the plexiglass and the
frame was well sanded and thickness controled with popsicle wood sticks.
I think the trouble is the paint that I used on the frame.The fix was
holes and pop rivets. I am making the skirt rigth now so in few days I
may have some pictures available.
Antoine
Wow, I hope the paint was the problem. My canopy frame was
powder-coated from the factory, and it seems to be stuck on
pretty well.
Thanks for the information!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
bkbrown(at)ashcreekwirele Guest
Posted: Sat Jul 08, 2006 4:23 pm Post subject: Gluing Canopy Skirt - RV-8 |
FWIW, before gluing the canopy and windscreen (and skirts) on my 7A frame and fuselage with Sikaflex, I bought some black Sikaflex295UV and did a few Dr. Destructo pull tests using scrap pieces of plexi and pieces of both powder coated steel and aluminum. Thickness of the adhesive beads was controlled with rubber hose washers at 3/16ths inch per the product data sheet manuals. On one pull test, I tore the aluminum sheet (.032) and the Sika joint never failed. In all my other tests, the plexi failed. The Sika joints never failed. I can only presume the product that failed was out of date (either the primer, the wash or the adhesive or all) or there was some other contaminant present at the point of adhesion. This product has been sold as an adhesive for polycarbonate and plexiglass for years. It is recognized as an industry standard for the application we are using it for. I suppose time will tell, but there are installations in RV’s out there now with over 5 years on them. If anyone knows of any other failures, I’d sure like to hear the details about them. I can only speak about my installation, which shows no sign of being anything but solid. I did return some tubes of Sikaflex which were out of date when I received them. I’d suggest looking at those dates closely. One thing I’ve learned from using Sikaflex 295 is that it will absolutely not stick to a surface that has not been properly prepped (both surfaces sanded w/60 grit, washed, primed). Also note there are time limits…wait 20 minutes after the wash coat before priming. Adhesive must be applied within 2 hrs of priming. I used to freak out if I got some Sikaflex on the canopy outside my masked bead area…later I just left it on until it cured, because it would peel off as easy as rivet tape if it was not applied over a properly prepped area.
Bob
_______________________________________________
Bob and Karen Brown
RV7A - flying
martin(at)gbonline.com Guest
Posted: Sun Jul 09, 2006 6:56 pm Post subject: Gluing Canopy Skirt - RV-8 |
Mike,
In reference to your comment "speeds that other RV8s can only dream abount".
This statement has left me with a bit of skepticism.
I am assuming that this statement means that your RV8 is faster than all of
the others. It would seem to me that you would be anxious to demonstrate
your prowess in the Air Venture Race just before Oshkosh. Their is still
time to squeeze in a potentially class winning participant. Contact Eric
White immediately and he may be able to squeeze you in the Race.
I , John Huft and Dave Anders would really enjoy some j
"high speed" competition.
Dick Martin
RV8 N233M
the fast one
