dean.psiropoulos(at)veriz Guest
Posted: Sun Jan 15, 2006 10:00 pm Post subject: Instrument install/annunciators |
Those who have been here already...when you put the steam gauges in your
panel, how do you fit the ones with the knobs sticking out of one corner?
For the (United Instruments) altimeter it looks like I won't have a choice
and will have to hog out some of the corner of the panel where the knob goes
(big bump in the case under the knob). However, for the MD200 OBS (VOR/ILS
indicator) and the 2 inch G meter (Falcon Gauge) the knobs have small posts
that would likely fit through the screw hole if the knob were removed before
installing the gauge. Can the knobs on these gauges be removed prior to
installing the gauge and then re-attached afterwords? Or am I just going to
have to make a small slot between the cutout and the screw hole? Also, what
exactly is the bit size used to drill these screw holes? #6 screws???
Annunciator lights, I'd like to find some square ones with the colored
plastic and engraved text that shows what subsystem is having a problem
(commercial airline pilots know them well). I have had some great input
from an RV-6A pilot who rolled his own. I've perused the web quite a while
and haven't found much that might work for my application (mostly round
lampholders with colored lenses but you couldn't really engrave them with
text like I'm wanting). Any suggestions on this one? The only other option
I can see is to use the round lampholders and have engraved text underneath
each one with the subsystem being annunciated. Not the optimum solution but
given what I've found so far, looking more and more viable all the time
(probably simpler and quicker too). Thanks.
Dean Psiropoulos
RV-6A N197DM
Gonna fly this spring!!!
rene(at)felker.com Guest
