occom(at)ns.sympatico.ca Guest
Posted: Sat Jul 15, 2006 9:40 am Post subject: Question for the old timers |
I am dissassembling the rear spars from the wings on my IV for replacement. The previous owner began repairs and I am undoing some of that.
My question surrounds the epoxy used by Denney in 1992. Where I am removing the original epoxy it has some "give" to it and surrenders quickly to the hot knife arrangement I am using. The newly glued surfaces use Hysol and it is hard as a rock and rather more resistant to heat.
So, what was the original adhesive?��If both are the same Hysol adhesive, what is the difference? Cotton flox?
BTW I can now confirm that it takes much longer to disassemble a wing (assuming you want to use the�ribs over) than it takes to build one.
morid(at)northland.lib.mi Guest
Posted: Sat Jul 15, 2006 10:11 am Post subject: Question for the old timers |
Dave, the original adhesive was probably 3M 2216.� It's good stuff, but it had to be mixed 1/3 - 2/3 which was a bit of a bother.� The good thing is that it can be removed with heat.
Deke
wliles(at)bayou.com Guest
Posted: Sun Jul 16, 2006 4:03 am Post subject: Question for the old timers |
My Avid used the same adhesive and it cured to a quite hard surface when
correctly mixed. It could not be easily dented with a fingernail. If the
adhesive on your set of wings can be easily dented and is somewhat
pliable then I suspect it was not mixed in the correct ratios or the
glue was past its shelf life before it was used. Fortunately in the
wings the structure will develop almost its full strength when properly
assembled with the shrunk on fabric without glue. Dean Wilson, the
original designer, of the Avid said the glue served mainly to keep
things together so it could be covered. As I understand it Kitfox even
went so far as to assemble a glueless wing and test it. None-the-less
improper gluing of the wing would make me a bit concerned about the
workmanship in the rest of the plane.
Jerry Liles
Dave G. wrote:
Quote: | I am dissassembling the rear spars from the wings on my IV for
that.
to heat.
So, what was the original adhesive? If both are the same Hysol
(assuming you want to use the ribs over) than it takes to build one.
Posted: Sun Jul 16, 2006 6:49 am Post subject: Question for the old timers |
Posted: Sun Jul 16, 2006 7:41 am Post subject: Question for the old timers |
Dave,
I beg your pardon. You requested input on the adhesive and I told you
what I knew. Avid and Kitfox used the same adhesive. I know this
because I helped a bit with the assembly of a Kitfox wing while building
my Avid. I told you what my experience was and what I thought. I don't
think my post was insulting to either you or the original builder, nor
were the replies from other list members. I don't have your airplane
here to inspect so I can't comment directly on the workmanship, however,
apparent improper gluing would still make me suspect. It is possible
the original builder used a different epoxy.
Jerry Liles
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jul 16, 2006 8:31 am Post subject: Question for the old timers |
I dare say even the Hysol can be cut with a hot knife. In the Lancair list
there is occasional talk of opening a wing or other structure for corrective
work. The technique as I understand it is to use heat to undo the Hysol
joints and brute force to separate the others.
One characteristic of "structural" epoxies is that they have a bit more
elasticity than the hard lay-up epoxys. This to allow them to move a bit
under load rather than simply crack. This would illustrate the validity of
the structure opening technique - soften the adhesive and use a putty knife
to pry it open then break the hard stuff.
Lowell
Posted: Sun Jul 16, 2006 8:33 am Post subject: Question for the old timers |
eccles(at)Chartermi.net Guest
Posted: Sun Jul 16, 2006 10:00 am Post subject: Question for the old timers |
Hi all
on my series V the bonding epoxy was 3M 2216 A/B and was mixed 2/3 per
volume if that helps any.
Posted: Sun Jul 16, 2006 10:05 am Post subject: Question for the old timers |
Very tactful reply Dave. I agree that the replies to your other posts were
probably well meaning, but with emails it's difficult to inject tone and
often, with poor wording, they can be taken as being critical. I try to
allow my posts to simmer for a bit then reread them before hitting the send
button, however even that isn't always successful. Generally, at the very
least I catch some atrocious spelling and grammar errors, but I digress...
As for the adhesives, both of the 3M 2216 or Hysol 9430 are good and will do
the job. Some folks just think the Hysol is easier to work with.
Deke
ps: Still haven't received any details on the watermellon social. Also,
anybody know where we can get a map to the Acey Ducey lounge?
Quote: | No pardon nescessary and I wasn't insulted. I was informed by another
lister
Quote: | that the original adhesive is likely 3M 2216 which he described as
slightly
Quote: | flexible and removable with heat, so that seems likely.
I will confess to being a little short of patience with the number of
condemnations of the entire aircraft based on questions I've asked. I do
welcome input but as you say, you cannot evaluate the structure from your
end. General concerns about workmanship of the entire aircraft are
probably
Quote: | best left to the owner and the DAR.
I had asked a while back about an odd repair that I doubted, (spliced
spar)
Quote: | without providing any background. I recieved no less than four emails, all
well meaning I'm sure saying that the entire structure was doubtful on the
basis of this one untried repair when all I needed to hear was that it was
a
Quote: | bad idea and that it should be replaced.
In any case, I do welcome your reply and it is possible that we
misunderstand each other. There are many questions I might ask badly. I am
fascinated by the idea of the glueless wing, especially after the amount
of
Quote: | time the adhesive is costing me, but I've already got these two cans of
Hysol...
