stevesrv7(at)gmail.com Guest
Posted: Sun Jul 16, 2006 7:53 pm Post subject: Main bus wire feed |
I was reviewing the Z diagrams in Bob's book and am curious about the circuit protection coming into the cockpit from the battery contactor. There is an ANL fuse shown between the alternator and the batt contactor, but there is no fuse on the (typically) 6 or 8 ga wire coming from the batt contactor into the cockpit. What is the reason to not protect such a large wire as it goes through the firewall? I'm sure Bob has thought this through, I just don't know the reasoning behind it and am hoping someone here might know. Thanks. Steve
nuckollsr(at)cox.net Guest
Posted: Mon Jul 17, 2006 5:11 am Post subject: Main bus wire feed |
At 09:51 PM 7/16/2006 -0600, you wrote:
| Quote: | I was reviewing the Z diagrams in Bob's book and am curious about the
What risk is to be mitigated by adding such
protection?
There are numerous instances of "exposed" or seemingly
risky situations in configuring hardware. For example,
there's an invisible, fast moving, deadly body basher
on the nose of your airplane that will turn you into
hamburger in a heartbeat. Why don't we put a wire cage
around it to protect against such events?
The cost-benefit ratio study says that operationally
we can conduct due-diligence in making sure fragile
things don't get into the prop and therefore, the
weight and performance losses for protecting it are
of no practical value.
Okay, apply the same thinking to the piece of "un
protected" wire you've identified. Get out your hammer,
crowbar or any other favored instrument of force and
then look over the wire and it's terminating bus installation.
See if you can identify any piece of the airplane that
even MIGHT come against it such that there is risk
of a fault.
I believe you will find (as have many who have studied
this problem before us) that there are no risks associated
with leaving this wire unprotected beyond observing
due diligence in supporting the pieces so that vibration
or other motion does not compromise insulation.
Study the wiring diagrams for any production aircraft
and see if builders of those airplanes deduced any
risks that warranted the protection you've cited.
It's a good question. The answer is, "Risks associated
with this practice have been deduced by analysis and
proven by field experience to be insignificant."
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
