dmasys(at)cox.net Guest
Posted: Tue Jul 18, 2006 1:14 pm Post subject: Roller painting |
Oh boy com'on everybody knows you use a roller....the white primer takes the alodine well though and makes for a nicer golden color that alodining first.
Actually, I did use a roller for the first coat of UV smooth prime on the cowl, ( http://www.aircraftspruce.com/catalog/cmpages/09-28290.php ) and found it was a great way to fill pinholes and build up the surface for sanding.
It is in fact a good white primer for fiberglas surfaces, no joke.
-Dan Masys
40448
Rick S.
Posted: Tue Jul 18, 2006 1:40 pm Post subject: Roller painting |
"Actually, I did use a roller for the first coat of UV smooth prime on the cowl"
You are correct sir!!! That is the best way to apply that product, after I posted my little humorless response I remembered that product and it's application with a roller.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
